Nd filter for 200t outdoors
#1 Lisala Dolo
Lisala Dolo
  • 15 posts
  • Sound Department
  • London+Southampton UK
Posted 17 September 2008 - 05:04 AM
Hi i shot some super 8 footage with 200T and an 85b filter on a Nizo 4080 - I was very happy with the results apart from the sky being over exposed ( )- flagged up as too much luminance on final cut pro. Will an ND filter of some type help out or is there some other way ?
Also I use the wide angle atatchment alot on the same camera (over 100mm diameter)- does anyone know of a suitable matte box or a diy solution - as much as i like lens flare i could do without it alot of the time.
Thks Lisala (Professional sound recordist - Amateur camera)
#2 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 17 September 2008 - 12:07 PM
Yeah, you can use graduated filters. Although the pro version usually mounts on a matte box filter holder tray, there is a system that may work screwing it directly on the Nizo lens.
http://www.bhphotovi...r_ONLY_for.html
You just have to find the right size adapter ring and graduated filter you want. The Z Pro is the biggest filter system, and you may find something for your wide angle adapter. Although if you just want to flag the sun, something like this may work:
http://www.bhphotovi..._Flag_Only.html
#3 Lisala Dolo
Lisala Dolo
  • 15 posts
  • Sound Department
Posted 18 September 2008 - 08:06 AM
Thanks for the great links - are these cokin type filter holders much better than the screw on photographic types ? - obviously they are easier and quicker to change and like you say all of the shoots i work on(sound recordist) the cameras have these type on the matte box.
