AC'ing with a Letus 35mm adaptor, question?
#1 Allan Legarth Nielsen
  • 21 posts
  • 2nd Assistant Camera
Posted 19 September 2008 - 12:12 PM
Hi
Got a small job for this weekend. Think we're shooting with either HVX200 or Sony EX1, anyways, we're using a Letus 35mm adaptor, and I suddenly got a little confused.
Aren't I suppose to measure from the adaptor (where the picture gets projected on the rotating disc) or is that wrong, is it from the cameras chip I'm measuring?
Allan
Edited by Allan Legarth Nielsen, 19 September 2008 - 12:13 PM.
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 19 September 2008 - 12:23 PM
Hi
Allan
Assuming you using motion picture lenses then the rotating ground glass. The chip on the camera is irrelevant.
Stephen
#3 David Carstens
David Carstens
  • 18 posts
Posted 19 September 2008 - 12:37 PM
Stephen
While the focus plane on lens adapters are "supposed" to be the ground glass, the build on many of them are usually sub-par out of the box. I've found that the collimation of various mounts often needs to be tweaked- the Letus doesn't have the same level of engineering of P+S's micro/Pro35 units. Just make sure shoot a full set of focus tests or you may find a good deal of soft shots going solely off of tape measurements... Even then, I'd feel better with an on-board HD monitor to keep my mind at ease!
#4 Allan Legarth Nielsen
  • 21 posts
Posted 19 September 2008 - 02:51 PM
Sh**t. Well I guess I'll figure it out, cheers!
More tips and experience stories are appreciated though ;)
Edited by Allan Legarth Nielsen, 19 September 2008 - 02:51 PM.
