Rigging light from Rooftop
21 replies to this topic
#1 Markus Harthum
Markus Harthum
  • 14 posts
  • Vienna. Austria
Posted 04 October 2008 - 05:42 AM
Hi everyone,
I need to rig a light outside a window. The light used will be a 2500W HMI Par. The window is in the last floor of a 5 storey high building, so it's not possible to rig it from the ground. But we have access to the roof and i think it's possible to rig from there.
I have attached an image to show the shape of the roof, as it is a bit complicated to explain.
The roof has a little fence at the edge, an then the first 2 feet or so are lower then the rest of the roof. But the difference in height is just 1/2 feet and can be leveled out with appleboxes.
My idea would be to take a 9feet long alluminium pole and rig the light to it, while putting a LOT of weight on the other end. Additionally securing the pole on the fence. The Pole would exceed the edge for 3 feet and stay on the roof for 6 feet.
But somehow i think there may be a better solution. Any ideas?
Markus
#2 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 04 October 2008 - 09:52 AM
servas markus! :rolleyes:
what's going to be underneath the lamp?
public gehsteig or a hinterhof that can be locked down?
#3 Markus Harthum
Markus Harthum
  • 14 posts
  • Vienna. Austria
Posted 04 October 2008 - 11:04 AM
Servas alex,
so we see us again:-)
there will be no danger to people or animals. The lamp will hang over a terrace, which we can close off.
#4 timHealy
timHealy
  • 1262 posts
Posted 04 October 2008 - 04:57 PM
Steel pipe would be better than aluminum. And you could also add a rachet strap the to end of the pipe to a point higher than the pipe like to the top of the railing if it strong enough for added support.
Best
Tim
#5 Sebastian Andexer
Sebastian Andexer
  • 22 posts
  • San Antonio, Texas
Posted 06 October 2008 - 02:03 PM
Why dont you just goal post that poop. throw a combi on each side, some pipe and youre set. Rigging something like a 2.5 like is more trouple than its worth.
#6 Chris Pritzlaff
Chris Pritzlaff
  • 187 posts
Posted 08 October 2008 - 12:59 AM
Not when it is 5 stories off the ground
#7 David Auner aac
David Auner aac
  • 1117 posts
Posted 08 October 2008 - 01:27 AM
Morgen Markus,
I think you're okay with what you are suggesting. Buit I guess you should safety the bugger with some chain to a post of that roof-top fence. Just to be sure. Would be a shame if that lovely 2,5k drops to an untimely death!
Cheers, Dave
#8 Markus Harthum
Markus Harthum
  • 14 posts
  • Vienna. Austria
Posted 08 October 2008 - 05:14 AM
Hi
Thanks for your replys.
I think i'll do it in the way described and secure it to the fence, and secure the fence to something else, just in case.
Markus
#9 William Palmer
William Palmer
  • 1 posts
Posted 08 October 2008 - 11:40 AM
Assuming the ground and budget allow, how about renting a cherry picker or other lift. For a movie here in South Carolina the crew rented a fire department platform (ladder) truck to put lights outside a window.
#10 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 08 October 2008 - 06:55 PM
Menace Arm.
#11 Chris Keth
Posted 08 October 2008 - 07:50 PM
What you're suggesting will work fine. Just make sure it's safetied well to something that absolutely will not budge if the lamp somehow comes loose. It will be a pain to adjust the lamp once it's in place. If it's the kind of thing where you will set the lamp and not touch it the rest of the day, then I wouldn't think twice about your method.
#12 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 08 October 2008 - 07:59 PM
a 2.5HMI is not something you can secure to a fence. You might be able to rig to the building with cribbing and large c-clamps, but I'd have a better feeling with a menace arm that has a safety on the light, and the stand.
#13 XiaoSu Han
XiaoSu Han
  • 162 posts
Posted 09 October 2008 - 07:04 AM
just use a doppelkurbler :P
use panther weights and everything will be fine
#14 Onno Perdijk
Onno Perdijk
  • 87 posts
  • Grip
  • www.solidgripsystems.eu
Posted 09 October 2008 - 04:14 PM
Hello Markus,
Basically your idea with the given circumstances seems to be okay. I would suggest to add some piping going down beside the window and some crosspipes to make it more stable and less vulnerable for wind.
See attached image. Using steelpipe or truss would be recommendable. When you could use truss you can use a sleeveblock or trussdolly to get te lamp in its correct position and slide it in for making adjustments, change filters etc.
good luck,
Onno Perdijk
KeyGrip
Amsterdam Holland
#15 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 09 October 2008 - 05:02 PM
how would you connect the green pipes? Using truss?
#16 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 09 October 2008 - 07:08 PM
Just curious what the light is meant to be, considering it's a 2.5k HMI so close to the window and shining directly inside. Will you be needing a way to rig some diffusion as well?
#17 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 10 October 2008 - 02:47 AM
Jesus, we forgot THAT part!!! Rigging anything else off the pipe won't be hard, but getting it just right will!
Anyway to shoot this from a different location? (that would have been my first question upon location scouting)
#18 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 10 October 2008 - 02:59 AM
Maybe he can get a stronger light and then get permission from the building across the street to use their roof to set the light up there...if there is a building there.
#19 Warwick Hempleman
Warwick Hempleman
  • 115 posts
  • Germany
Posted 10 October 2008 - 04:19 AM
None of this has yet solved the problem of getting everything hung on the end of the rig before pushing it into position. If there's a way to use something like a menace arm and then swing or roll it out over the window, that's your easiest way. Maybe a lightweight crane (GF-6, Foxy or the like) could work as a base for the whole thing? Put it on track and on boards and you can get where you want to be, plus you can raise and lower the lamp in addition to moving it closer or further away.
Not to add more overkill to this, but solve the diffusion problem (and the lamp positioning problem) with a motorized yoke and DMX-controlled gel changer (Mag Max from Licht-Technik comes to mind). L-Ts yoke controls include all lamp functions (pan, tilt, focus) as well as barn door movement
#20 Evan Pierre
Evan Pierre
Posted 11 October 2008 - 01:46 AM
How far below is that terrace you mentioned, could you get a stand on there?
