Issues Importing EX-1 Footage into FCP
14 replies to this topic
#1 Jerome White
Jerome White
  • 23 posts
  • VA/NYC/PHL/LA
Posted 13 October 2008 - 10:12 PM
Hey everyone,
my co-worker has an issue importing the EX-1 clips into FCP. We was on a recent shoot together, and he dumped the footage from the SxS cards onto his computer. And after he was done he deleted the footage from the SxS cards. When dumping the footage, he just used the XDCAM Clip browser and it is saved onto his external hard drive. His issue is, how can he go about importing the clips into FCP since he did not import them through FCP?
#2 David Brickley
David Brickley
  • 18 posts
Posted 14 October 2008 - 12:42 AM
Hey everyone,
This shouldn't be an issue, he should be able to import the footage without any problems (Apple + i, then select clips). I have done the same process on my PC with my EX1 and haven't had any hang-ups. I work as an assistant editor with FCP... if your editor wants to send me a clip I'd be happy to try importing it at work and let you guys know how it goes.
-Dave
#3 Jerome White
Jerome White
  • 23 posts
  • VA/NYC/PHL/LA
Posted 14 October 2008 - 08:27 AM
-Dave
Thanks, I will tell him to do this and see how it goes. The clips are in multiple folders, it includes an XML file as well. So would he have to select more then one file? or can he just select all folders and it will automatically import them?
#4 David Brickley
David Brickley
  • 18 posts
Posted 14 October 2008 - 02:11 PM
He should be able to set up his folder view options so he can select multiple files and import them in one fell swoop by setting the view so that it can drop down (triangles will be next to folders). I believe that will allow you to bring in multiple files at once.
Let me know how it goes, good luck!
-Dave
#5 Jerome White
Jerome White
  • 23 posts
  • VA/NYC/PHL/LA
Posted 14 October 2008 - 05:43 PM
-Dave
It still did not work. He sent me a screen shot of the folder and what it contains (see below). Maybe there is just one file he is suppose to import? This is how he is trying to import the file/folders. Here are his steps, File > Import > Files. He is running FCP 6.0.4. Sorry for the huge screenshot.
Edited by Jerry White, 14 October 2008 - 05:44 PM.
#6 Adrian Sierkowski
  • 7374 posts
Posted 14 October 2008 - 07:35 PM
I'm just sorry I can't see the background.
Try running that folder again through the clip browser software. You'll want to choose the option "export mxf for nles"
#7 Jerome White
Jerome White
  • 23 posts
  • VA/NYC/PHL/LA
Posted 14 October 2008 - 09:19 PM
The screenshot just showed the folder he is unsure he should import.
the main xdcam folder > BPAV > CLPR > 689_0131_01 > an mp4 file, .smi file, .ppn file, .xml file, .bim file.
Is he suppose to import the whole folder that contains these files or the mp4? When he tries to import either the whole folder it does not work, as well as just importing the .mp4 file. I will tell him to try the export and let you guys know. We greatly appreciate the help so far though.
#8 Adrian Sierkowski
  • 7374 posts
Posted 14 October 2008 - 09:27 PM
should be the BPAV as that is the main herarchial file structure folder. That would be imported into the clip browser software, or perhaps FCP ( not 100% on that as I use XDcam on the Avid)
#9 Jerome White
Jerome White
  • 23 posts
  • VA/NYC/PHL/LA
Posted 14 October 2008 - 09:42 PM
Same thing I was thinking, but still says "error" when trying to import. Something told me to just import it through FCP first. But we figured we could just copy the files on the external hd and import them later.
#10 Adrian Sierkowski
  • 7374 posts
Posted 14 October 2008 - 09:50 PM
are you getting the error in FCP or XDCam software?
#11 Jerome White
Jerome White
  • 23 posts
  • VA/NYC/PHL/LA
Posted 14 October 2008 - 10:04 PM
The error is coming from FCP. He is trying to import the copied clips through FCP.
#12 Adrian Sierkowski
  • 7374 posts
Posted 14 October 2008 - 10:21 PM
Think you're beyond being able to do that. Think you have to go through the clipbrowser software if it's not working. That should make it work. There is also a plugin for FCP that he ought make sure he has. Both are available on the sony xdcam website
http://pro.sony.com/...eDownload.shtml
#13 David Brickley
David Brickley
  • 18 posts
Posted 15 October 2008 - 08:42 AM
Wow this topic exploded since yesterday... have him select the mp4 file (the one with the Quicktime logo), that should import with it's native resolution just fine. An MXF file is needed for Avid, but FCP is Quicktime-based so I believe the mp4 should come in fine.
Also, if anything else goes wrong make sure he moves the window a little to the right so we can all get a peek at that background!
Edit: I see you said he tried to import just the mp4, is there a small size BPAV folder you can post up on an FTP? I can try it over here and see if it comes in.
Best,
-Dave
Edited by David Brickley, 15 October 2008 - 08:46 AM.
#14 Jerome White
Jerome White
  • 23 posts
  • VA/NYC/PHL/LA
Posted 15 October 2008 - 04:36 PM
Thank you everyone. We finally was able to import it. Thanks for all the help. Greatly appreciate it!
The solution was re-installing the plug in, and reimporting it through Sony XDCAM and it worked.
#15 David Brickley
David Brickley
  • 18 posts
Posted 16 October 2008 - 08:25 AM
Great to hear Jerry, hope it turns out well!
