Nizo S 560 & Canon AutoZoom 814 Exposure
#1 martin sc
martin sc
  • 2 posts
Posted 21 October 2008 - 03:58 PM
hi everybody!
I got a Nizo S560 and a Canon AZ814 some time ago. I am planning to shot some scenes for a documentary on super8. So I have some questions about the exposure time of the nizo and canon. Do both cameras have a constant exposure time for each fps setting? or do they have an automatic esposure time...
best regards
#2 Rick Palidwor
Rick Palidwor
  • 407 posts
Posted 21 October 2008 - 05:40 PM
hi everybody!
best regards
The exposure time varies with the filming rate (fps).
Exposure time = (1/speed in fps) X (angle of shutter opening/360)
With both those cameras the angle of the shutter opening like 150 or 170 degrees (someone else here might know exactly).
Rick
#3 nate lavey
nate lavey
  • 2 posts
Posted 23 October 2008 - 05:08 PM
i think this is right (please! correct me if i'm wrong):
i'm pretty sure the canon 814AZ has a through the lens light meter so you probably don't need to know the shutter angle for metering through the lens (because the meter already knows the angle). but suppose you are using an external meter...
the canon has a shutter angle of 155 degrees (according to super8wiki and the canon museum page)
so:
(1/speed in fps) X (angle of shutter opening/360) = Exposure time
(1/24) x (155/360) = 0.0179398148 ... which is pretty close to 1 / 56 = 0.0178571429
so for the 814 i guess we can say the exposure time is right around 1/56.
my question is, can we just do some easy rounding to 1/50th for light meters (like the common sekonic l-398) that don't have that exposure time?
xo
#4 Rick Palidwor
Rick Palidwor
  • 407 posts
Posted 23 October 2008 - 05:55 PM
You are right that Canon has Through the Lens metering (as does Nizo I believe) so yes, internal meter should be accurate (if working properly). I always use internal meter and would have mentioned this, but it was not the original question, though you anticipated the logical follow-up question.
Good to know.
Rick
Edited by Rick Palidwor, 23 October 2008 - 05:55 PM.
#5 martin sc
martin sc
  • 2 posts
Posted 24 October 2008 - 11:35 AM
thank you both for your help...
yes, I want to use an external meter. so I think it should work with 1/50 sec for 24fps
best regards
martin
