Lighting Advice for shooting objects on fire
#1 Joseph Barnett
Joseph Barnett
  • 5 posts
Posted 05 November 2008 - 06:01 PM
HI,
I normaly shoot coverage so I am quite new to lighting, so any advice you can give me would be hugely helpful.
Im shooting three short set peices with a locked of camera (objects on fire) with the intention of projecting these 1:1 in site specific locations. Each film will be a household objects on fire set against a large white purpose built fake wall. im looking for quite a clean flooded difused look. The end result esentialy needs to look like a white poster, with the objects on fire + graphics txt etc.
What would be a good set up to shoot this? if you can give names for the lights that would be really helpful.
Thanks in advance,
Joe
#2 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 05 November 2008 - 06:51 PM
Sounds like a famous Pink Floyd Album Cover...
Shoot the Fire at 4 - 5.6 on 100t. Light the White Cyc to 3 Stops (Reflected) Over... and make sure the 'Object' has plenty of Fill.
Use 1/2 CTBlue on all your lamps and your (Color Chart) if you want a 'Redder' Fire... or use HMIs (5500) for even 'Redder-er' Fire.
Edited by David Rakoczy, 05 November 2008 - 06:55 PM.
#3 Daniel Porto
Daniel Porto
  • 201 posts
Posted 05 November 2008 - 07:28 PM
So are you sugesting that in post you correct the fill (which is either 1/2 CTB, or HMI color temp) as white to produce the redness in the fire. If so, it might just be easier to buy a filter which converts half way (is it the 81B???) or use an 85.
Your post just confused me... typo maybe or am I just an idiot?
#4 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 08 November 2008 - 04:30 AM
Adding the filter will make 'everything' go warmer.. adding the 1/2 Blue or shooting on Daylight Stock with 5500k Light will make the Fire 'itself' go warmer... I should have written this way:
Shoot the Fire at 4 - 5.6 on 100t. Light the White Cyc to 3 Stops (Reflected) Over... and make sure the 'Object' has plenty of Fill... you could also add 1/2 CTBlue on all your lamps and your (Color Chart) if you want a 'Redder' Fire... or use HMIs (5500) with 50D for even 'Redder-er' Fire.
I hope that makes more sense...
#5 Daniel Porto
Daniel Porto
  • 201 posts
Posted 09 November 2008 - 06:57 PM
Yes that certainly does!
Thanks!
