film 16mm vs lens for 35mm
#1 firdaus
firdaus
  • 10 posts
Posted 22 November 2008 - 12:56 AM
my question :
if i shot film 16mm or sony hdcam with lens for 35mm (eg.50mm) do i have the same FOV than film 35mm with 35 lens ??
anyone can help me explaine and the formula to calculate about this..thanks
best regards
#2 Chris Keth
Posted 22 November 2008 - 02:49 AM
Good evening, firdaus. First off, please change your display name to your full first and last name as per the forum rules.
The field of view shown with a given focal length will change depending on format. For example a 35mm lens on spherical 35mm will have a horizontal angle of view of 33.4º. Put that same lens on Super 16mm and you get an angle of view of 19.1º. Furthermore, put that exact same lens on a 2/3" inch video camera and you have an angle of view of 15.6º.
Each format is just using a different part of the cone of light projected by the lens.
I calculated these numbers with Panavision's Image Calculator. There are also tables with this information in the ASC Manual.
Edited by Chris Keth, 22 November 2008 - 02:51 AM.
#3 firdaus
firdaus
  • 10 posts
Posted 24 November 2008 - 10:37 PM
thank you very much chris, now i can use the panavision calculator..thank's
firdaus
