latitude with HD
#1 anthony le grand
anthony le grand
  • 80 posts
  • france
Posted 27 November 2008 - 11:46 AM
Hi guys,
I have a short film to shoot in 2 months and we only have the money to use HD cams like the HVX200 or the EX1. At the moment, my choice is the Sony one but I saw that the P2 and the JVC HD111 had good results as well, even if they are différent.
I think that the colors are a lot richer with the EX1 but do you know if the latitude with this cam is bigger than with the other ones?
Do you advise me to underexpose it 1 stop? That's what I usually do with digital but don't know about that one.
Also, I've heard some people saying that there's 2 issues with that cam.
The first one is to import the footage (I'll be working with Final Cut).
The second one is resolution drop when you move the camera. It's a real issue for me cause I'll be working with a steadicam and moving a lot (even if it will be quite slow).
Could you tell me anything about that?
Thanks a lot
#2 Jim Hyslop
Jim Hyslop
  • 213 posts
  • 2nd Assistant Camera
  • Toronto, ON, Canada
Posted 06 December 2008 - 12:34 AM
I have had no problems importing footage from an EX1 into Final Cut. I have a MacBook Pro, which has the PCI Express slots, so all I had to do was download the drivers for the SxS card.
Transferring files is simple: Plug in the card, drag the files to the working drive, eject the card (you can now reuse it) launch FCP, go to "Log and Transfer" and ingest.
Jim
#3 samuel phibbs
samuel phibbs
  • 6 posts
Posted 11 December 2008 - 04:53 PM
I think Adam Wilt on provideocoalition said the ex1 had 10 stops of dynamic range which I am pretty sure is more than the jvc has.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 December 2008 - 04:56 PM
The dynamic range beats the competition as does the resoloution, the EX1 is a no brainer IMHO.
Stephen
#5 John Sprung
John Sprung
  • 4635 posts
Posted 11 December 2008 - 06:14 PM
Resolution drop due to movement is a problem with interlaced cameras, but given the same frame rate and progressive scan on both, the EX-1 should be better both locked off and hand held. The one thing that's strange about it is that the photosites aren't lined up vertically and horizontally, they're on a diagonal pattern. This helps with aliasing on a lot of common high detail items, but should be hell on a chain link fence. That's one thing we didn't see in the tests at VTP.
#6 anthony le grand
anthony le grand
  • 80 posts
  • france
Posted 18 December 2008 - 09:00 AM
Thanks guys for your answers.
After a few tests, you're definitely right, there's no doubt that the EX1 is better than the others in latitude, resolution and flexibility to have the look I want.
Thanks for your help
