A Question to All
7 replies to this topic
#1 Sean Lyons
Sean Lyons
  • 21 posts
  • Texas
Posted 04 December 2008 - 04:14 AM
Ok everybody I have this annoyance.
After I get done recording a broad cast for my churches cable show I go to pack up my tripod and wrap up my cord that was just run across the church and back. As of right now I'm just wrapping it into a big neat circle. I've tried to be creative and did a figure eight once. hehe But both tend to be time consuming and sometimes irritating.
So my question to all is, is there a "method/technique" or pattern to wrapping my cords that would make my troubles disappear? Any sort of on-set trick to wrapping a large amount of cord up in a timely and neat fashion.
If there are any neat/impressive patterns that would make me look like a BAMF then plz by all means let thy cometh forth and speak, for we are not worthy. :P
Thanks for reading!
Happy Shooting!
-Sean Lyons
#2 Igor Trajkovski
Igor Trajkovski
  • 311 posts
  • Macedonia
Posted 04 December 2008 - 05:04 AM
Try over-under coiling !
Here is a video demonstrating the technique:
Over/Under
Cable Wrapping Techniques
Regards
Igor
PS:... if i got it right what you where asking... :D
#3 Daniel Sheehy
Daniel Sheehy
  • 407 posts
  • Brisbane
Posted 04 December 2008 - 07:10 AM
Over-under.
It may not make you look like a 'BAMF', but it'll be good for your cable... and time saving only comes with practice.
#4 Sean Lyons
Sean Lyons
  • 21 posts
  • Texas
Posted 04 December 2008 - 03:44 PM
I knew the "over and over" but I like the over and under better.
But the cables that run onto my camera are not xlr. It's a few cable (which I don't know the name of) tied together with zip ties. So the over and under method would not work with this size of cable.
They are the cables that we run from the camera, down the hall to our control room, which feeds the video into our monitor system and then we capture it. If that makes since, I'm trying to explain the setup to the best of my knowledge :rolleyes:
Hope that helps,
-Sean lyons
#5 Adrian Sierkowski
  • 7374 posts
Posted 04 December 2008 - 04:25 PM
should be coaxial with a BNC type connector. . and over under should work for them fine as well. . .I mean hey; it works for my garden hose (though I'm partial to 1/4 hand twist.)
#6 Daniel Sheehy
Daniel Sheehy
  • 407 posts
  • Brisbane
Posted 04 December 2008 - 04:59 PM
...But the cables that run onto my camera are not xlr. It's a few cable (which I don't know the name of) tied together with zip ties. So the over and under method would not work with this size of cable..
It'll work for your cable, there is no restriction to this method based on the size of the cable... I mean, hey, if it works for 3-phase power and multi-core audio, it'll work for anything. :)
The fact that you have several cables zip-tied together won't affect it.
#7 Sean Lyons
Sean Lyons
  • 21 posts
  • Texas
Posted 05 December 2008 - 03:13 AM
That's very true. I don't know why I didn't think of that.
ok well cool. I guess that solves my problem, but I'm still extremely curious to see what some others can bring up. Maybe somebody can blow my mind and make me look at life in a different perspective.
Or maybe i'm just asking for too much. hehe ;)
-Sean Lyons
#8 Evan Pierre
Evan Pierre
Posted 05 December 2008 - 04:29 AM
I don't think it will blow your mind but here is a video I came across recently that could prove helpful to a beginner: The Grip Guide: Proper Use of Cables
Good luck!
