Best way to sync audio?
7 replies to this topic
#1 Nick Castronuova
Nick Castronuova
  • 40 posts
Posted 05 December 2008 - 06:59 AM
I shot a 16mm short and had it transferred to mini DV. The audio was recorded on a Flash recorder. How will I go about syncing?
Do I convert the video to 24fps in Cinema Tools first? And then what's the easiest way to sync?
#2 Jason Debus
Jason Debus
  • 311 posts
Posted 05 December 2008 - 04:42 PM
Hi Nick,
If you didn't slate (clap) the shots it's a difficult job. If you can hear the noise from the camera when it's running then that's probably the best alternative.
#3 Tom Hepburn
Tom Hepburn
  • 341 posts
  • Chicago-land
Posted 05 December 2008 - 05:09 PM
Nick,
Does your camera a crystal sync motor? If not it's going to be tough, but not impossible. Unless you have long (as in minutes) shots that are continuous.
That is the first things to post.
Tom
#4 Nick Castronuova
Nick Castronuova
  • 40 posts
Posted 06 December 2008 - 08:04 AM
Hey, I shot crystal sync on the Arri SR-2 and slated. Do I just sync the old fashioned clapboard match way?
I tried converting my footage to 24 FPS in cinematools (I shot 24fps but had it telecined) and now it seems not to sync with the audio at all. Any suggestions? Maybe i put in the wrong presets.
#5 Jim Hyslop
Jim Hyslop
  • 213 posts
  • 2nd Assistant Camera
  • Toronto, ON, Canada
Posted 06 December 2008 - 09:41 AM
Yep, that's all there is to it.
When you say it doesn't sync at all, is that after syncing up the slate "the old fashioned way"? How long before the sound goes out of sync?
#6 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 06 December 2008 - 01:16 PM
If you're cutting on computer, you can get away with a head and tail slate and not even run sync. You'll spend time in post lining up the slates. But, it's doable. Given that, you can put your sound on darn near anything as long as you've got the slates. I'm not saying it's a good idea. Just doable.
#7 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 07 December 2008 - 12:58 PM
Open Clip in cinema tools, conform to 24 fps.
Change sequence settings in fcp to 24fps.
import and drag the conformed clip (video only) to the time-line of your 24fps-sequence, that's it
cheers, Bernhard
Edited by Bernhard Zitz, 07 December 2008 - 12:59 PM.
#8 Michael Chobot
Michael Chobot
  • 4 posts
  • State College, PA
Posted 13 January 2009 - 07:47 PM
When you transfer to DV, you are going from true 24fps to (30) fps. The problem is that the 30 is actually only 29.97 fps. If you want to sync it directly in something like final cut, without touching the picture, you want to slow down the audio by -0.1%. That will make your audio and video match, then just go by the clapboard.
Mike
