Fire light effect
#1 DJ Kast
DJ Kast
  • 38 posts
  • Green Bay, WI
Posted 05 December 2008 - 09:14 PM
I read in an issue of AC that for "There Will Be Blood" the gaffer rigged up a box that house numerous peanut bulbs on a circuit that randomly dimmed and flickered. Then he mixed CTO and theatrical reds to augment color. They didn't go into more detail on how it was build, and I was curious if anyone had some ideas on how to get the lights to do this without putting strings of lights on dimmers and have a few guys turning them up and down.
#2 Josh Silfen
Josh Silfen
  • 53 posts
Posted 06 December 2008 - 12:18 AM
Magic Gadgets makes dimmers that produce random flicker.
http://www.magicgadgets.com/
#3 Chris Keth
Posted 06 December 2008 - 12:24 AM
I don't know how much current they will take, but you can wire a bulb through a fluorescent striker and it will make random flicker. A few of those together looks pretty good.
#4 Matthew Parnell
Matthew Parnell
  • 289 posts
  • Electrician
  • Brisbane, Australia
Posted 06 December 2008 - 04:06 AM
You can get flicker generators that both internally generate the flicker which you can set various parameters into them to emulate different types and sizes of flame, but also have a photosensitive sensor that can be used to emulate a fire source that is in frame. I have seen these units capable of handling max loads from 1kva to 5kva.
My favorite method of getting this effect is to have a lamp, which is flickering bounced into a suitably sized frame with silver or gold lame' which is being shaken.
#5 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 06 December 2008 - 07:43 AM
I have found that you don't need much. For me a simple two lamp scenario works well. First lamp on steady with some yellow or Orange gel. Second lamp (small wattage on a flicker gelled with another yellow to orange slightly off from the first.
http://www.bluesky-web.com/fire.mov
That is the effect of a campfire using the flicker box I sell.
#6 DJ Kast
DJ Kast
  • 38 posts
  • Green Bay, WI
Posted 07 December 2008 - 12:28 AM
Thanks for all the great suggestions.
#7 chris kempinski
chris kempinski
  • 75 posts
Posted 07 December 2008 - 02:00 AM
On the movie Pathfinder we waived our hands in front of maxi brutes with spot bulbs, from close range
Oh yeah! That was fun
