Apple Pro Res 422
22 replies to this topic
#1 Marie Davignon
Marie Davignon
  • 9 posts
  • Montreal, Quebec, Canada
Posted 17 December 2008 - 10:26 AM
I shot a film in super16mm and we're finishing it in HD.
We opted for the Apple Pro Res 422 codec.
Does anyone have any info that I should know about this codec? Is it looking far more different than QuickTime Uncompress HD 10 bit (which is to heavy to edit on a normal computer)?
Thanks for your advices and concerns!
Edited by Marie Davignon, 17 December 2008 - 10:27 AM.
#2 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 17 December 2008 - 11:02 AM
Your choices may be determined by the final target format. If you are planning a film out, you'll want to transfer to uncompressed HD. Otherwise, the ProRes format may be well suited as an online format. If your budget allows for it, your best option would be to transfer your masters to uncompressed HD, then rendering to ProRes proxy files for editing.
#3 David Ghast
David Ghast
  • 33 posts
Posted 23 March 2009 - 02:30 AM
Dont do it. Thats all i have to say. You've been warned.
#4 Tom Hepburn
Tom Hepburn
  • 341 posts
  • Chicago-land
Posted 23 March 2009 - 09:04 AM
Not a lot of detail as to why David. Any chance you could expound a bit?
Tom
Edited by Tom Hepburn, 23 March 2009 - 09:04 AM.
#5 timHealy
timHealy
  • 1262 posts
Posted 23 March 2009 - 10:06 PM
Aren't there two versions of ProRes?
ProRes 422 and ProRes 422 HQ?
Best
Tim
#6 Rick Martinez
Rick Martinez
  • 14 posts
Posted 24 March 2009 - 09:14 AM
I would go uncompressed.
ProRess 422 go up to 145Mbps and HQ reach 220Mbps according to Apple.
the format can work 4:2:2 / 10-bit.
But remember that introduces some compression algorithm that must sacrifice some info to reduce file size.
Regards,
#7 Ross Neugeboren
Ross Neugeboren
  • 110 posts
  • Electrician
  • Greater NYC
Posted 24 March 2009 - 02:57 PM
Since you mentioned computer strain in Uncompressed HD 10 bit, if you don't have a super-powerful computer to work with, you're probably going to want to go with an offline workflow. Probably the best way to go about this is to do your assembly edit off ProRes 422 proxies of your uncompressed footage, creating an EDL. Then go back online (final cut will automatically take you through bringing in your online, uncompressed media) and perform your final edit. This will save you a lot of processing power during the assembly.
There's a chapter about the whole offline/online process in the final cut pro user manual. (Chapter 5, page 57)
Edited by Ross Neugeboren, 24 March 2009 - 03:00 PM.
#8 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 25 March 2009 - 08:48 AM
Please explain. Were you using ProRes HQ?... on what system?.... what happened?
#9 Erik Turestedt
Erik Turestedt
  • 25 posts
  • Sweden
Posted 28 March 2009 - 11:23 AM
Since I wen't with prores 422 there is nothing else for me!
It kicks ass...
Thats all I can say. Never had any problems with it. Picture is awesome.
I'll post from film to prores 422 on some tests soon. The lab (stockholm post production), said that they do this quite often. Of course 2k or uncompressed HD is a bit better... But on the other hand, I can't imagine that something shoot on s16 cut prores 422 then recorded on for example cinevator or more expensive arriprint still wouldn't look great! This process but with HDcamSR looks very good on the big screen, even if many would say the only way is 2k scan.
I'm impressed by prores. But keep in mind that still I haven't recorded or printed back to film for the big screen, so I can't answer how it looks in cinema from prores..
And when it comes to efficency prores is so good codec! Never got any bad renders! I even cut things on my intel macbook white with 1,2gb ram without any lag or slow workflow! Imagine doing that on a pc!
When it comes to the technical details I cant say I know much... Other than that prores is full raster! Meaning that there is no HD 1440x1080 upres. It's full 1920x1080 pixel to pixel as I understood it.
Only bad thing I saw was when I ran 1280x720 with red text from AE. The text looked a little bit like it had deinterlaced artefacts. But then again, red color is always a warningbell, and should used with precation.
I use prores today mainly for shooting commercials, shot HD. And next up is film! I'm looking forward for the tests, shoot either s16 or 35 2perf...
#10 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 28 March 2009 - 01:08 PM
Yep.. I just finished rebuilding and upgrading my Edit Suite with the new MacPro and am going tapeless!
35mm & S16mm to HDCam (for master transfer archive) then to a G-Raid in ProResHQ. I'll receive all Film footage on the G-Raid.
Really looking forward to the next Project we do! I am banking this will improve the quality of the Images we deliver...
Unfortunately, some simply leave a negative message and don't back it up with a more detailed (useful) description of any issue(s)... oh well :rolleyes:
#11 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 29 March 2009 - 08:58 AM
You'd be better off TKing to HDCam SR, otherwise your Pro Res 4:2:2 files are coming from a 3:1:1 source.
#12 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 29 March 2009 - 09:29 AM
Yes indeed.. I left the SR off...
#13 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 29 March 2009 - 09:53 AM
Hi-
I just had a short 35mm project transferred to SR, and the lab gave me both an uncompressed QT along with a proresHQ file. Comparing both side by side, the prores looked to me to be just the slightest bit grainier, and a tiny bit more saturated, but the differences were negligible.
I didn't have to do any greenscreen or major CC with the footage so I don't know how well the two would stack up under those conditions, but I assume the uncompressed would handle it better.
The dire "You've been warned" bit above is complete BS.
#14 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 01 April 2009 - 05:56 PM
Stuart,
Just spoke with my (LA) Transfer House and they said that both HDCam and D-5 are 4:2:2... They said HDCam SR is (slightly) better.. ever so slightly.. but you can stay in 4:2:2 with either HDCam or D-5 as well... maybe you were thinking 4:4:4???
#15 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 04 April 2009 - 11:23 PM
Hi-
Did Sony change their specs or something? HDcam has always been 3:1:1.
#16 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 05 April 2009 - 08:40 AM
Hi-
hmmmm, yes I see that Patrick on wikpedia.. I will call them again.. it is a BIG Transfer House and I was speaking with a guy in Data Management... gets Tape to Hard Drive. Either way I will use the SR Tape but I wonder what they were thinking.....???
#17 Adrian Sierkowski
  • 7365 posts
Posted 05 April 2009 - 10:17 AM
HDCam SR can be 4:2:2 or 4:4:4... perhaps they just used HDCam to refer to HDCam SR.
#18 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 05 April 2009 - 12:25 PM
Hi Adrian,
We were real specific.. they said HDCam, D-5 and HDCamSR are all 4:2:2.
Gonna call them Monday morning..
#19 Adrian Sierkowski
  • 7365 posts
Posted 05 April 2009 - 12:37 PM
Hmm.. Odd.. maybe they were just a bit bleary eyed!
Let us know what they say.
How are things in FLA?
#20 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 05 April 2009 - 04:02 PM
B)
