Building a circular track?
12 replies to this topic
#1 Nicholas A Micros
Nicholas A Micros
  • 19 posts
  • Philadelphia
Posted 17 December 2008 - 10:41 AM
Is it possible to build a circular track out of PVC? I wanted to keep the track light and easy to transport. Never herd of such a track, anyone else have??
p.s
first post!
#2 Reil Munro
Reil Munro
  • 12 posts
  • Grip
  • Manitoba, Canada
Posted 17 December 2008 - 08:22 PM
Nick
No, I've never seen PVC circular track before, and in all honesty don't want to be using any PVC track..ever!
But that's just me.
Good Luck with the build
Stay Classy...and welcome to the forum
Reil
#3 Chris Keth
Posted 18 December 2008 - 03:27 AM
Never seen it. My guess is that it's probably pretty tough to bend PVC with a perfect radius and without wrinkles in the inside of the bend.
Why don't you try it with a heat gun and a form? It may be easy, it may not be.
#4 Warwick Hempleman
Warwick Hempleman
  • 115 posts
  • Germany
Posted 18 December 2008 - 04:32 AM
Nick,
Welcome to the Forum. There's a thread lower in this Forum about circular track, which discusses dimensions and other pertinent information, so you might want to read that first. There have been a few manufacturers of plastic track and circles. A rental house in your area may have some or know where to get a circle.
Apart from the technical criteria for making your circle, the problem in the field will be leveling it. Here metal will show itself to ber a much easier, faster, and (in terms of all the material you'll transport) lighter way to go. And as I usually do, I recommend looking into rental prices first before you start the construction project.
#5 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 18 December 2008 - 05:50 PM
Ira built one. Do a search and you should be about to find the thread on one of these categories. If I'm NOT mistaken, it could be under general discussion. You may also just PM him and ask. He used a heat gun, sand and a jig to to slowly curve the track without collapsing the PVC tubing. I don't remember how it came out.
#6 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 18 December 2008 - 06:44 PM
Actually, I WAS mistaken, it's right here in this category. Do a search for "curved track" and 5 or 6 will come up including both of Ira's posts.
#7 Nicholas A Micros
Nicholas A Micros
  • 19 posts
  • Philadelphia
Posted 18 December 2008 - 09:18 PM
Thanks everyone, extremely helpful. Much better than dvxuser!
#8 Ira Ratner
Ira Ratner
  • 558 posts
  • Coral Springs, Florida
Posted 18 December 2008 - 10:54 PM
James, you got some memory! WOW!
Nick, it's real easy and cheap to do from PVC. And if you're doing video as opposed to film (me), you'll have no problems quickly ironing out any bugs.
The main thing is the connections, where you want the dolly to seamlessly ride over them.
#9 JD Hartman
JD Hartman
  • 1763 posts
  • Edison, N.J. U.S.A.
Posted 24 December 2008 - 12:35 PM
These guys make curved PVC track. http://www.longvalle...p.com/index.php
#10 Nicholas A Micros
Nicholas A Micros
  • 19 posts
  • Philadelphia
Posted 28 December 2008 - 04:26 PM
Ratner
Originally, we were going to shoot video however there is some talk of going 35 with this short. It is still early in pre-production so we are still figureing everything out.
The shot is going to take place on a small one way street in philadelphia, which is far from flat. So I am hopeing we can shim the track to level it but I know that idea is far fetched.
JD
Thanks for that amazing link. Hopefully the production can put that track into the budget.
#11 Warwick Hempleman
Warwick Hempleman
  • 115 posts
  • Germany
Posted 28 December 2008 - 09:43 PM
Nick,
You can level anything, anywhere. It's a matter of having the material and time (and of course the money) available to do it. Leveling a street for a circle is mostly a time equation. If the street is sloped, you may want to build a platform that the track and the actors are on. This can be gotten from many sources, and you can probably get the crew to assemble it from those places, too. You would need to close the street for quite some time, probably a day.
#12 Ira Ratner
Ira Ratner
  • 558 posts
Posted 30 December 2008 - 08:12 PM
Nick, what kind of diameter are you talking about? The entire width of the street? Or something less intense?
Also, although Warwick is assuming a full circle, I was assuming you just want 180 degrees, because circular track doesn't necessarily mean full circle.
Edited by Ira Ratner, 30 December 2008 - 08:15 PM.
#13 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 31 December 2008 - 03:45 AM
The shot is going to take place on a small one way street in philadelphia, which is far from flat. So I am hoping we can shim the track to level it but I know that idea is far fetched.
What do you mean " far fetched"? You have to level dolly track, it's not optional. That's what cribbing, grip wedges and a 4 foot level are for at least up to about half a foot or so, above that you can use apple boxes to support the track up to about 2 feet still leveling with grip wedges but above that you have to build supports but you RARELY have to go above that on a small shoot. Don't know what cribbing and grip wedges are? Look it up, we can't do everything for you. :D OH alright, I'm a softy (yeah right!!! :rolleyes: ) Here are some links:
http://www.cinematog...Dolly_Track.htm
http://books.google....o...8&ct=result
http://www.abelcine....p...t&task=view
http://books.google....P...1&ct=result
There, that should get you started. If you're gonna do this, do it right, capish? B)
