2:1 anamorphics on s16mm?
#1 Hunter Hampton
Hunter Hampton
  • 170 posts
Posted 24 December 2008 - 03:18 AM
So I have this crazy idea; There are a quite a few 2K screens in my area, and I am planning a feature shot on s16mm in a few months with a DI... would I be crazy to shoot with 2:1 anamorphic lenses and project from the full aperture? (3.32:1 or something?)
It has got me thinking with the ease of making a 2K-DCP with that aspect ratio, and also most likely the only theater run of the film would be locally at these digital screens anyways... I think 3.3:1 would look good, but maybe I am just being a little to far out? What do you think?
  • 20072 posts
Posted 24 December 2008 - 03:29 AM
You'd have to show it letterboxed to 3.36 : 1 either in a 35mm anamorphic print, or 2K projection -- there is no DCI spec to cover 3.36 : 1.
#3 Hunter Hampton
Hunter Hampton
  • 170 posts
Posted 24 December 2008 - 04:00 AM
Right, that would cut down on the resolution during projection.
I really like the artifacts from shooting anamorphics and I plan on intentionally flaring the lens for many scenes which would exaggerate some of that. I guess the real question is can I really shoot with 2:1 anamorphics on s16mm and and get away with screening 3.3:1... or would I be better off just shooting 1.85:1 with spherical lenses?
Just thinking out loud! ; )
#4 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 24 December 2008 - 04:26 AM
Vantage Film have 1.33 anamorphic lenses designed for 16mm. Best speak to them. But I'm not sure how widely these lenses are available yet.
Otherwise you can letterbox S16 to 2.35 and do either an optical or digital blow-up to 35mm. That way your film can play anywhere. I've seen an optical blowup a couple of years ago and I was very impressed, it held up very well on the big screen.
#5 Hunter Hampton
Hunter Hampton
  • 170 posts
Posted 24 December 2008 - 06:11 PM
I wonder what the rate is for those 1.33x lenses, im guessing they are expensive- thanks for the info though. I think I will try a screen test and see how a 2K letter-boxed DCP holds up.
#6 lentsoe mamatela
lentsoe mamatela
  • 2 posts
  • south africa
Posted 29 December 2008 - 03:21 AM
im curious, the whole anamorphic thing boggles me a little, i understand the size ratio the image is projected, however on s16mm for example does is give one a closer image to one of 35mm..?
and projection...how does it influence what one can project...?
thanks...
#7 timHealy
timHealy
  • 1262 posts
Posted 29 December 2008 - 06:36 AM
for what it is worth and if I have my facts straight, the new movie The Wrestler shot in Super 16 and framed for cropped widescreen format, then I assume they did a DI.
Anyone with any corrections feel free to join in.
Best
Tim
#8 David Mullen ASC
  • 20072 posts
Posted 29 December 2008 - 11:46 AM
Super-16 is 1.68 : 1, full aperture.
4-perf 35mm print projection is either matted widescreen (usually masked by the projector to 1.85) or anamorphic widescreen (a 2X squeezed image on the print is stretched by 2X; the print area is around 1.20 : 1 and the unsqueezed image becomes around 2.40 : 1 on the screen.) And both formats have an offset image in order to have room on the left for an optical soundtrack.
So no what what format you shoot, you have to end up as one of these two 35mm print formats if you plan on striking release prints.
Putting anamorphic lens on a Super-16 camera could only cause an improvement IF it caused you to crop the 1.68 negative LESS to create one of these two 35mm print formats. Unfortunately, a standard 2X anamorphic lens is too much of a squeeze for a 1.68 negative -- you end up with a 3.36 : 1 image that would have to be cropped on the sides to get a 2.40 image, so there is no quality advantage compared to cropping top & bottom to get a 2.40 image when using normal spherical lenses on a Super-16 camera.
It's all about negative real estate more or less.
Using these new 1.33X Hawk Vantage 35mm anamorphic lenses on a Super-16 camera would get you more negative area for a blow-up to 2.40 than cropping Super-16 top & bottom to get it. However, you'd have to deal with a lack of short-enough focal lengths to get wide-angle shots on the smaller negative.
#9 Jann Doeppert
Jann Doeppert
  • 4 posts
  • Ludwigsburg / Stockholm
Posted 31 January 2009 - 03:24 PM
I shot this short with the HAWK C-Series (2:1) on S16 using a little less than the N16 neg-area. The neg was scanned at 2k and reframed during telecine...
Edited by Jann Döppert, 31 January 2009 - 03:25 PM.
