Speed changes within clip in FCP
#1 Kristian Schumacher
Kristian Schumacher
  • 175 posts
  • Oslo, Norway
Posted 31 December 2008 - 05:00 PM
Hi everyone!
I have a question that should be simple, but I can't figure it out. I have some 16mm footage that I shot at 200-250fps scanned and loaded in my FCP 6.0 project. Now I want to ramp up and down the speed within the clip, ideally gradually, to leave only parts of the clip in slow motion while some faster. Some sort of key frame- speed change function that will let me tweak the speed at several points within the clip.....?
Any help appreciated :rolleyes:
And Happy New year!
Kristian
#2 Jim Hyslop
Jim Hyslop
  • 213 posts
  • 2nd Assistant Camera
  • Toronto, ON, Canada
Posted 01 January 2009 - 02:11 PM
There are two ways to do this. The one I find easier is the "Timing" feature in Motion - it's on the "Properties" tab of the Inspector. Within FCP itself, there's the time remap function, on the "Motion" tab in the Viewer. Neither one is particularly easy to use - you'll have to work with them a bit to figure out how they work.
Jim
#3 Kristian Schumacher
Kristian Schumacher
  • 175 posts
  • Oslo, Norway
Posted 01 January 2009 - 02:49 PM
Thanks a lot Jim,
I will give both those ways a try and see what works best.
Kristian
Jim
#4 Steve McBride
Steve McBride
  • 239 posts
  • New York, NY
Posted 29 January 2009 - 10:32 PM
Time ramping may be easier to do in Motion. But if you want to keep in FCP, just set a keyframe for your Time in the Motion tab move forward 5 or so frames and make another value to have it be a bit smoother.
You could also do this in AfterEffects and use Easy Ease keyframes which would be even easier. Check out videocopilot.net for tutorials on AfterEffects.
#5 Kevin Fox
Kevin Fox
  • 8 posts
  • Digital Image Technician
  • VA, USA
Posted 30 January 2009 - 03:11 PM
Also try Creative Cow for AE tutorials. creativecow.net
Best,
kfox
