Kodak B&W Neg IR sensitivity
#1 Gregory Almond
Gregory Almond
  • 24 posts
  • Anywhere
Posted 02 January 2009 - 10:55 AM
How sensitive is Kodak Plus-X or Double-X film to infrared light? I assume they are low in sensitivity, however a project i am working on could possibly require infrared lighting and i want to make sure if necessary i am to compensate.
~G
#2 Gregory Almond
Gregory Almond
  • 24 posts
  • Anywhere
Posted 02 January 2009 - 11:01 AM
I went onto wikipedia and it said that infrared was 750nm - 1mm in wavelength, and the filmstocks had a sensitivity from 400nm to slightly>650nm, so that would mean the light is beyond the films capacity to expose.
Is this correct?
#3 Simon Wyss
Simon Wyss
  • 1491 posts
  • Basel, Switzerland
Posted 02 January 2009 - 12:56 PM
Yes, it is. The rest has to do with the lenses.
#4 Mark Dunn
Mark Dunn
  • 2659 posts
Posted 02 January 2009 - 03:04 PM
Ordinary mono film is only sensitive to IR in the sense that you shouldn't get it hot. You can't image it.
B/W IR film is exposed through a deep red filter, to absorb the visible wavelengths to which it is slightly sensitive- those pesky reds around 650-750nm.
#5 John Salim
John Salim
  • 190 posts
  • Essex, UK
Posted 20 February 2009 - 07:31 PM
~G
Gregory, These films are not sensitive to IR. I use IR safelighting ( with viewing goggles ) in the lab for all colour and B&W film ( except IR films of course ).
Film that's damaged by heat, is damaged by heat ! not IR.
John S
Edited by John Salim, 20 February 2009 - 07:33 PM.
