Synching multiple Stobes
7 replies to this topic
#1 Stephen Murphy
Stephen Murphy
Posted 08 January 2009 - 06:10 AM
Is there anyway i can synch multiple (consumer) strobes to the shutter of a single camera? Uisng 3 - 4 strobes in any given shot and I need to be able to shoot at 25, 50 and 100fps, shooting on an SR3.
#2 Alfeo Dixon
Alfeo Dixon
  • 121 posts
  • Atlanta
Posted 08 January 2009 - 10:30 AM
if you can get one to fire with the camera, I would look into using the old photo slave technology which means you have to step up to a pro-consumer unit that will take a sync cord. Just plug the slave into the pack instead of the sync cable and make sure it sees the main light. One trick we would do is pull the slave into an stinger and put them closer in the line of the main flash.
#3 Chris Keth
Posted 09 January 2009 - 01:28 AM
Some strobes like white lightnings are photo-slaved. If you switch them to that setting, they will fire with large, sudden changes in light intensity. There are no cables involved if you use an on camera flash as a trigger. Otherwise, you'd need to cable to one unit or use something like a radio sync.
#4 Chris Keth
Posted 09 January 2009 - 01:37 AM
I missed the part about consumer strobes. I assume that means you already have them.
In that case I would recommend a wireless radio sync system. Google "pocket wizard." It's a transmitter that you plug into your camera or meter's sync cable socket. The receiver plugs into the power pack or into each head if they're the portable kind with the power unit on each individual head. They have quite good range, I've used them up to a hundred feet or so.
#5 Stephen Murphy
Stephen Murphy
Posted 09 January 2009 - 05:26 AM
Thanks guys
#6 Dave Green
Dave Green
  • 31 posts
  • 2nd Assistant Camera
Posted 09 January 2009 - 07:02 PM
If this is for broadcast in the UK, then remember you can't have quicker strobing than 3 flashes per second (if I remember the rules correctly).
I would be confident in betting that it will be something similar for cinematic releases in the UK and around the world, too.
#7 Chris Keth
Posted 10 January 2009 - 04:58 AM
Never heard of any rule like that. I've seen strobing on screen that would make probably an epileptic person seize.
#8 Stephen Murphy
Stephen Murphy
Posted 10 January 2009 - 06:44 AM
Wasn't aware of that myself either:-) ;)
