Manual for Hitachi 16mm Highspeed
#1 David Auner aac
David Auner aac
  • 1117 posts
Posted 13 January 2009 - 08:56 AM
Hi fellow 16mm freaks,
for an upcoming shoot I'm thinking of buying a Hitachi 16mm highspeed camera from the late 70s to early 80s. It's model is listed as Hitachi Highspeed 16HM. Is equipped with a Nikon F mount and takes 2r film (obiously) has a 400' magazine (nice!) and does (supposedly) 100-10 000 fps. Does anyone have any info on that camera? Or know someone I could ask? Thanks!
Regards, Dave
#2 David Auner aac
David Auner aac
  • 1117 posts
Posted 17 January 2009 - 01:00 PM
Ok, I give up. It seems this camera will end up as a paperweight on someones desk or continue taking up space it the store rooms of the local camera store... Nothing. Spent two days calling around. Thanks anyway!
Regards, Dave
#3 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 17 January 2009 - 03:51 PM
Regards, Dave
I can't say I am surprised. I did not know Hitachi had made film cameras (let alone hi speed) and I simply cannot find much or any info about them online, much less a manual for one. :(
That sucks. And you are sure you cannot figure it out? Seems like a thing too good to pass up . . .
#4 David Auner aac
David Auner aac
  • 1117 posts
Posted 18 January 2009 - 04:14 AM
Hi Saul,
yeah I thought so too. But now I found a Locam II at a quarter of the price for the Hitachi. And I do have the manual already, if only digitally! The really nice thing about the Hitachi was the 'native' F mount while on the Locam I'll have to fiddle with adapters from Photosonics to C and maybe to F mount from there. We'll see. Good thing is that the camera cost about as much as I had estimated for a one day rental! And it's gonna be the only workable 16mm Highspeed in my neck of the woods!
Regards, Dave
PS: Thanks for your sympathy! :D
#5 kevin jackman
kevin jackman
  • 350 posts
Posted 22 January 2009 - 09:10 PM
would you be willing to hand out copies of the locam manual? also, is it possible to post some pics of the Hitachi?
#6 David Auner aac
David Auner aac
  • 1117 posts
Posted 23 January 2009 - 03:32 AM
Hi Kevin,
sure, but if you check out my thread on the Locam II somebody already posted a link to the manual. Here you go LocamII manual. The Hitachi can be found here: 16mm Hitachi Highspeed. IIRC there is on on ebay as well.
Regards, Dave
#7 alexandros petin
alexandros petin
  • 106 posts
  • Athens Greece
Posted 23 January 2009 - 07:52 AM
hello !
i have shot with an c to f adapter (nikon brand) and it works with good results. It is sharper compared to footage shot with the same adapter and a bolex rex4, (many factors for that, the prism of bolex, the registration of locam etc) also the c mount mount of locam seems by far more robust than the the turret of the bolex.
if you get your locams
maybe we should organize a festival LOCAMII TEST SHOTS hehe
seeya
#8 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 23 January 2009 - 11:39 AM
What do you need to know? I used both professionally a while back. The Locam we called medium- rather than high-speed as it only reliably went up to 400fps. It would run off battery or a 13A socket (at 240V).
The Hitachi went to 5000 full-frame or 10000 half-height and needed a 60A supply to run up to speed in a reasonable time.
The Locam is sharper, of course, having a pin-registered movement as against the Hitachi's rotating prism.
Be very careful about cleaning after a run. The Locam will stop and start, with the Hitachi it's one shot per 400' roll, and tweezers and a vacuum cleaner needed to clean it out.
#9 David Auner aac
David Auner aac
  • 1117 posts
Posted 30 January 2009 - 02:54 AM
Hi Mark,
thanks. Which Locam model was that? Hearing about the Hitachi being one shot per mag I am happy I didn't buy it. The power supply was the main problem. The wiring on the thing is really strange and I wouldn't have been able to figure out the pins and the volts needed without some kind of doc. It's strange you don't find anything on this one. It seems to have been rather common as there are two or so on ebay as well, currently. 60A in 120V would make that 30A in the 230V world. Or are you walking 60A at the needed secondary current?
Cheers, Dave
