problem with my projector Keystone
#1 Jorge Rondao
Jorge Rondao
  • 41 posts
  • Sintra-Portugal
Posted 18 January 2009 - 08:50 PM
Hello, I have a problem with my projector Keystone 2500,
when come back everything goes well but when I come to play can not stop the Flik the frame and always goes to jumps, has put oil in everything I tried to change the reels back the belt and I know what more there, from time to time but then hit back the same, it seems to me that the carriage of low to have a small advance what the film leaves no loose and starts to stretch to get off without guess this is it.
Excuse the bad English
Can anyone help?
If you must put photos of the interior of the machine to help me explain I put
Best regard
Jorge
#2 Terry Mester
Terry Mester
  • 323 posts
  • Welland, Ontario, Canada
Posted 26 January 2009 - 01:21 AM
Hi Jorge,
The problem of a jittery Frame is probably caused by the Take-up Reel tugging too strongly on the Film. I have the same problem with my Projector. I will soon be posting a Thread with pictures of a small Arm you can glue onto the Projector which will inhibit this tugging. A Super8 Projector does not have all of the fancy gears which a 16&35mm Projector has to prevent such tugging, but this Arm I propose will likely alleviate the problem. Keep checking for when I post that Thread. Below is an earlier Thread dealing with preventing jitteriness in the Camera.
At last, A SOLUTION TO JITTERINESS
http://www.cinematog...showtopic=32243
Here are some pages from my Website addressing this problem.
http://www.geocities...aintenance.html
http://www.geocities...manddigitalinfo
#3 Jorge Rondao
Jorge Rondao
  • 41 posts
  • Sintra-Portugal
Posted 26 January 2009 - 06:52 PM
Thank you so Terry, problem solved with only a strip of cardboard glued to create less tension in the tensor of the film in the projection window, now runs the whole movie until the end without jumping and very quiet and clear without scratching.
Now the problem is that, after having this resolved to no longer lamp light, perhaps burned by the diode be doing tests with it open and not refrigerate well, send to repair and not have it with me and now I can not put the photos of placement of the card.
Best Regards
Jorge
