Nikon D90 for DIY film telecine
#1 Regan Luke
Regan Luke
  • 5 posts
Posted 19 January 2009 - 10:01 PM
The Nikon D90 DSLR is capable of high definition video at 24fps. I am wondering if anyone has attempted to use this mode to convert their s8 or 16mm projections to digital. Any insight? Thanks
Edited by Regan Luke, 19 January 2009 - 10:03 PM.
#2 Regan Luke
Regan Luke
  • 5 posts
Posted 19 January 2009 - 10:28 PM
The samples Nikon provides:
http://imaging.nikon...en/d-movie/#c-4
I find the appearance pleasing, and for my purposes may serve well to film my projections. I've seen other DSLR's that can capture video at a high frame rate, but never thought of using one digitize. Hope I can develop a good workflow.
Edited by Regan Luke, 19 January 2009 - 10:30 PM.
#3 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 19 January 2009 - 11:12 PM
I wouldn't recommend it with the current firmware. I own that camera and I have big issues with the way the footage is compressed, and the rolling shutter. It may look fine online. But once you watch the footage off the camera and on a computer monitor, full size, then there are some serious issues with it.
Currently, any 1/3" CCD / CMOS HD camera such as Canon Vixia will look much, much better. Which is disappointing. but not strange as the D90 is a DSLR that also happens to record HD video - whereas the small HD vid cams have been designed to shoot motion pictures, yet happen to take stills as well. :blink:
Here is hoping Nikon will develop (and make available) a better firmware for the camera.
#4 Lars Fuchs
Lars Fuchs
Posted 30 January 2009 - 11:54 PM
In principle, this should work fine. You could check out moviestuff.com for some interesting setups. I don't think you'll have a CMOS rolling-shutter problem, since there is no movement during the exposure time. As I understand it the rolling shutter only causes problems when the subject moves (relative to the camera lens) while the shutter is open.
It might be a bit overkill though. I'll have to check the numbers, but I suspect the resolution of the d90 dwarfs that of a super8 reversal stock.
#5 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 31 January 2009 - 12:30 AM
The real problem you are going to have, if your projector doesn't have a variable speed control (like a Revere) is syncing the shutter speeds of the camera and the projector- for the D90 has no scan adjustment. And the D90's video resolution doesn't dwarf S-8's.
