how to process 7363 hi-con 16mm as a positive.
#1 Ara Mah
Ara Mah
  • 9 posts
  • Beirut
Posted 22 January 2009 - 11:23 PM
well, first post, i just finished shooting my film and i have a lot of rolls to process, can't wait to see the results! i already processed a 7266 bw tri-x reversal, and it turned out beautifully. my question is, how can i process my hi-con 7363 rolls as positives? do i use the same thing as reversal? or is there any other way? i already know how to process 7363 as negative, but i need to know how to do it as a positive. anyway, help?
Thanks.
#2 Brian Pritchard
Brian Pritchard
  • 330 posts
  • Rushden UK
Posted 24 January 2009 - 04:18 AM
Thanks.
This film is designed to be processed in D97 B/W positive developer. It is mainly used for shooting titles. The term negative and positive is really irelevlent. If you shoot black letters on a white background you will get white letters on a black background after processing, if you shoot white letters on a black background you will get black letters on a white background.
If you used a rostrum to shoot a b/w photograph the result would be a negative, if you shot a negative you would get a print.
You can also process 7363 as reversal, in which case you would get a positive if you start with a positive and a negative if you start with a negative.
It was quite common in the past to use high contrast stock with reversal processing and start with white letters on a black background to produce white letters on a black background for superimposing. You avoid problems with flare which can occur when photographing black letters on a white background.
You can download a datasheet from Kodak at
http://motion.kodak...._lab_h15363.pdf
Brian
Brian
#3 Ara Mah
Ara Mah
  • 9 posts
  • Beirut
Posted 24 January 2009 - 11:10 AM
Brian
Hey Brian, thanks a lot for the info and the data sheet. Last time when i processed my hi-con stock, i used D-19 to develop and then wash which gave me the inverted image. now i want to process it as reversal, but i'm not sure if the developing time would change a bit.
do u have any idea as to how long i should develop the hi-con? the first developer time in the reversal was 5 mins.
Thanks again.
#4 Brian Pritchard
Brian Pritchard
  • 330 posts
  • Rushden UK
Posted 25 January 2009 - 01:02 PM
Thanks again.
I don't have a time for 7363 but I would start with the same time you used for negative processing.
Brian
