Arri 2c battery and connector - 5 pin xlr pinout diagrams?
7 replies to this topic
#1 Ole Sundsby
Ole Sundsby
  • 13 posts
Posted 24 January 2009 - 10:13 PM
Hi all,
About to buy myself a battery/charger for my Arriflex 2c here:
http://www.batterysp...amp;ProdID=2014
However, the interesting thing is that I obviously need to know which of the 5 pins from the xlr that connects to the poles on the battery (+/-).
Does anyone here have a diagram showing which pin is + and which is - ?
Any help would be greatly appreciated!
Kind Regards,
Ole
#2 Chad Mayer
Chad Mayer
  • 12 posts
  • Portland, OR
Posted 26 January 2009 - 11:32 AM
Hi Ole,
I'm planning on buying the same battery from the same place! I've got their charger already on order.
I'm not sure what you mean by XLR because the Arriflex power connections are typically just two pins, their own type of connector. (I believe)
Did you or a previous owner adapt an XLR to the IIC motor connector/cable?
My battery connection had been changed to an XLR and I used a continuity tester on a multimeter to determine which of the XLR pins were being used for +/-. The specific XLR pins used were whichever ones the person who modified it decided to use.
Or maybe I'm completely misinterpreting your question,
-Chad
Hi all,
Kind Regards,
Ole
#3 John Sprung
John Sprung
  • 4635 posts
Posted 26 January 2009 - 04:34 PM
I'm familiar with 4 pin XLR, on which #1 is negative and #4 is positive, usually used for 12 volt systems. If you have a cable with the 2 pin Arri female connector going to the motor and a 5 pin for the battery, you could just check continuity with an ohmmeter. Or you could open up the XLR and see if you have red and black wires.
#4 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 26 January 2009 - 07:38 PM
Those old 5-pin XLR plug ends were on old Arriflex power cables. I'm not sure ARRI actually put them one there, I think they were aftermarket. I see them on cameras once in a while. I usually recommend to my clients that they let me cut them off and wire on a 4-Pin XLR as the old 5-Pin XLR battery packs are no longer available.
Best,
-Tim
#5 Ole Sundsby
Ole Sundsby
  • 13 posts
Posted 02 February 2009 - 11:37 AM
Thanks for your answers! :)
Both my Arri 2c and 2b actually has this same 2 pin to 5 pin XLR power cable (to connect with female 5pin xlr battery). I guess these were more popular in Europe, potentially, as both my cameras have been in German hands...
After a brief research online:
http://en.wikipedia....gital_Multiplex
http://pinouts.ru/Ho...12_pinout.shtml
I believe I've found the diagram I was looking for...However, one can never be too sure, as this is obviously not the common Arri 2c cable...
Not sure if my battery source provide these female sockets though...
#6 John Sprung
John Sprung
  • 4635 posts
Posted 02 February 2009 - 06:18 PM
These DMX pinouts are very unlikely to be what you need. Since you have the cables in hand, just ring them out with an ohm meter.
#7 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 24 February 2009 - 01:03 AM
IMHO 5 pin was used for 8 V on the earlier Arri ST models in Germany.
I would stick / convert to the 4 pin XLR as most modern battery belts use the polarity John described.
4 pin is standard for 12 Volts and also 14.4 Volts (i think the ENG cameras use 14.4) so you're likely to find these in rental houses.
For the complete cable:
http://www.cine60newyork.com/cable.htm
For the 4 pin Neutrik plug:
http://www.filmtools...txlrcabco4.html
#8 Ole Sundsby
Ole Sundsby
  • 13 posts
Posted 03 May 2009 - 09:33 AM
All,
Finally found a very useful document:
http://books.google....snum=3#PPA60,M1
Page 60 says it all.
Thanks to all for valid input!
Ole
