New to RED
#1 Olivier Martinez
Olivier Martinez
  • 33 posts
Posted 29 January 2009 - 04:37 AM
Hello all. I will be shooting my first feature at all and the production owns one RED. You can probably help me with some questions I have in mind: we want to shoot 4K / 2:1 with spherical 35mm lenses, if I need to shoot some highspeed work, I will switch to 2K, but can I still use the 35mm lenses? Will they become "longer", or do I need to take the 16mm lenses for 2K? Is it possible to shoot speedramps (25-100?) equal to the VSU-unit? Is there a viewfinder mask to compose for a posibble 2.40:1 ratio (if the producer want to get an anamorphic print out of it)? Thanks for some help!!
Olivier
#2 Mike Thorn
Mike Thorn
  • 64 posts
  • Grip
  • Cleveland, OH
Posted 29 January 2009 - 09:22 AM
They will produce identical results - the 35mm lenses become longer (taking a crop out of the center of the lens), and the 16mm lenses remain normal. At 2K, the 35mm lenses effectively become 16mm.
Yes. Check the RED user guide for detailed instructions.
Indeed there is! :) You can mask for 2.40:1, 16:9, and 2:1.
#3 Olivier Martinez
Olivier Martinez
  • 33 posts
Posted 29 January 2009 - 01:01 PM
Mike! Thank you :-) Best.
Olivier
#4 John Sprung
John Sprung
  • 4635 posts
Posted 29 January 2009 - 03:02 PM
... do I need to take the 16mm lenses for 2K?
Mid range to long lenses designed for 35mm film will work fine. When you need to go wide, the optical compromises required to cover the larger frame are a consideration. So, if you need anything wider than, say, 25 - 35 mm focal length for the 2K stuff, it would be better to bring along lenses designed for the 16mm film format.
#5 Olivier Martinez
Olivier Martinez
  • 33 posts
Posted 29 January 2009 - 04:59 PM
Thanks a lot for your advices! They will help me a lot!
Best.
Olivier
#6 Olivier Martinez
Olivier Martinez
  • 33 posts
Posted 30 January 2009 - 06:14 PM
I have another question in mind: the anamorphic frame will be squeezed in the DI-process? or later with the laser transfer for the masternegativ? Thanks again guys.
Olivier
#7 David Mullen ASC
  • 20068 posts
Posted 30 January 2009 - 06:44 PM
Olivier
The laser recorder just takes the cropped spherical image and burns or writes every horizontal row of pixels twice to create a defacto 2X squeeze on the 35mm intermediate stock. So you can just color-correct looking at a spherical image and just make sure that they mark it for cropping to 2.40 plus conversion to anamorphic in their instructions to the laser recorder.
#8 Chris Keth
Posted 30 January 2009 - 07:10 PM
I'll add that the generated framelines can be in any of several different colors, too. I mention it because I recently had an operator suffer through a few days of having trouble seeing the framelines because he didn't bother to ask me if they could be changed.
Edited by Chris Keth, 30 January 2009 - 07:11 PM.
#9 Olivier Martinez
Olivier Martinez
  • 33 posts
Posted 31 January 2009 - 10:34 AM
To David and Chris: Thank you!!
