Kern Switar 12.5-100mm f2 Aspheron
#1 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 30 January 2009 - 09:07 AM
Anyone know if this Lens is an RX lens, or do I have to stop down a little to use it on a Rex5?
#2 David Auner aac
David Auner aac
  • 1117 posts
Posted 30 January 2009 - 09:36 AM
FWIK it was available in RX only and it lacks a dog leg finder, so I think you're good. Do you have a C-mount or a Bolex bayo mount version?There were no non-reflex H16s in Bayo. I'm guessing C mount if you want to use on the REX-5. Just be careful with that heavy lens on the turret and use a locking plug!
Cheers, Dave
#3 Sam Wells
Sam Wells
  • 1751 posts
Posted 30 January 2009 - 10:07 AM
Did they even make this lens in c mount ?
Designed for the SB and SBM (essentially Rex 4 and Rex 5 with bayonet mounts) it would seem. Definitely "RX"
Nice lens.
The Aspheron is a front attachment for it which gives a 6.6 mm FL if I remember correctly on the wide end
-Sam
#4 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 30 January 2009 - 10:21 AM
It's a c-mount lens. I don't have the aspheron for it, but at least the back focus doubles up as a macro :)
thanks for the info on the RX
#5 David Auner aac
David Auner aac
  • 1117 posts
Posted 30 January 2009 - 10:23 AM
And there were two versions, the Vario Switar 100 PTL and the Vario Switar 100 MC with the latter being built in two slightly different flavours, one with a macro mode necessary for the Aspheron, the other without. Both the PTL and the MC were available in C and bayo mounts. Info taken from Andrew Alden's Bolex Bible.
Cheers, Dave
