1st Ac'ing on a ARRI 435
11 replies to this topic
#1 Allan Legarth Nielsen
  • 21 posts
  • 2nd Assistant Camera
Posted 30 January 2009 - 02:36 PM
I got my first 1st AC job on a 35mm short. As there is not budget enough for a 2nd AC, I'm also gonna be doing that job.....
Any notable things I need to know about that camera, mags etc? It's mostly gonna be tripod shots, but a few dolly shots are also planned
Any help will be appreciated.
Allan
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 30 January 2009 - 04:14 PM
Allan
Go to the rental house the camera is comming from & get them to show you what you need to know.
Stephen
#3 grant mcphee
grant mcphee
  • 93 posts
  • UK, Scotland
Posted 30 January 2009 - 04:25 PM
You can also get the manual and the 'quick guide' online.
Pretty easy to get your head around and reliable. LCD controls a bit similar to the sr3.
Take care when lacing mag onto camera incase you nick a perf. Make sure you have the correct loop size on mag. Older 435's sometimes will jam with 1000' mags at high speed. camera is very noisy at any speed. As it's a 435 they will probably want high speed stuff so check that you have correct shutter angle and maybe make a quick ready-reckoner for your pouch. If thre is time, get the jon fauer book.
As Stephen said, go to the rental house. They will be more than happy to let you look it over and it will put your mind at ease.
#4 Kar Wai Ng
Kar Wai Ng
  • 127 posts
  • Toronto, Canada
Posted 30 January 2009 - 04:43 PM
Avoid rolling out the mag, especially at high speed. You can end up with tons of tiny film chips in the mag, which can find their way underneath the film platens, in the throat, etc...essentially putting the mag out of service until you have the time to clean it out thoroughly, dissassemble the throat, etc. Since you don't have a 2nd or a loader, you really can't afford to spend time doing that...
#5 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 31 January 2009 - 09:18 AM
I'll second the Jon Fauer book as a great reference for the camera.
Especially if doing speed ramps with the RCU.
#6 Joel Phillips
Joel Phillips
  • 9 posts
  • Seattle
Posted 01 February 2009 - 02:27 PM
What is the title of the book?
#7 Tony Coan
Tony Coan
  • 18 posts
  • Philadelphia, PA
Posted 01 February 2009 - 08:25 PM
arriflex 435 book.
http://www.filmtools...435bookbyj.html
one thing to remember is that when you change the shutter angle via the rcu when ramping, when you unplug the rcu the shutter will stay at the last angle you had set. so be sure to double check that before shooting again.
#8 Aileen M Taylor
Aileen M Taylor
  • 13 posts
  • New York, NY
Posted 01 February 2009 - 10:48 PM
be very attentive of the loop size - once you load it a few times you'll get the hang of it and be able to load it the same each time, but that was tricky for my 2nd the first couple times he did it.
#9 Allan Legarth Nielsen
  • 21 posts
Posted 02 February 2009 - 03:26 PM
Nice thanks guys!
#10 Chris Keth
Posted 03 February 2009 - 02:22 AM
I have learned to pull the film to the farther edge of the loop-measuring line, rather than to the close edge. That gives about an extra perf that the camera seems to like.
#11 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 03 February 2009 - 03:12 AM
Here's a tip, since you're not having a 2nd or loader. Try and get as many mags as possible so you can preload a few in the morning. I don't know how much film your DP plans to burn, but I assume he's taking into account that you'll need time to download and load as the day progresses. But getting to set an hour earlier to have 4 to 6 hot mags on standby will save you a few pounds of sweat.
#12 Chris Keth
Posted 03 February 2009 - 03:27 AM
I hope you eat fast, too. ;)
