Grip/ Gobo Arm w/removable grip head?
24 replies to this topic
#1 Salil Sundresh
Salil Sundresh
  • 101 posts
  • 2nd Assistant Camera
Posted 03 February 2009 - 05:03 PM
I've been looking to purchase a grip arm or two and some grip heads. I've noticed the Matthews' arms have a grip head attached that cannot be removed, but I found calumet has an arm with a removable grip head:
http://www.calumetph...om/item/MF7011/
Being able to remove the grip head would be more versatile IMO and save money on buying more grip heads. My question is, are there any other companies that offer this? I couldn't find a reviews on the Calumet grip heads so I'm a little hesitant until I can try it out.
Having a removable grip head may not matter to those that are working with a 5 ton grip truck of stuff, but being an individual with limited funds I'm trying to get the best bang for my buck.
IE: Say I wanted to boom out a light from a stand, I don't necessarily need 2 grip heads to do this, I could remove one of the grip heads and use it to mount a flag or net on another stand.
#2 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 03 February 2009 - 05:47 PM
I'm pretty sure american cstands (or heads) are able to slip off, and they have a hex key on the side so you can completely remove the head and have just a pole (arm without a head).
I think you don't want the latter though.
#3 ChrisConnelly
ChrisConnelly
  • 29 posts
  • Grip
  • Philly
Posted 03 February 2009 - 08:35 PM
the head on a newer-style Matthews arm is completely removable, it's just bolted to the arm with a 3/8x16 bolt with a 5/32 allen head. the bolt is threaded exactly the same as the lockdown t-handle and goes in the same hole as on a separate grip head
#4 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
  • Anywhere they pay me to go
Posted 03 February 2009 - 11:27 PM
Buy just the Grip head. You can buy 5/8th stainless tube from a hardware shop, why pay a film company for something available off the shelf at any hardware store. Cut it to whatever lengths you want.
Sanjay Sami
www.thegripworks.com
#5 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 04 February 2009 - 01:27 AM
Sanjay Sami
*duh* was the first thing to come to mind after reading your idea sanjay! Great idea and so obvious, I can't believe I missed that.
#6 Salil Sundresh
Salil Sundresh
  • 101 posts
Posted 04 February 2009 - 02:42 AM
Sanjay Sami
Ya, i guess i just assumed it would be some non-standard size so I was hesitant to look into that. I'll have to check out the depot this weekend! Thanks!
#7 Mike Peters
Mike Peters
  • 17 posts
  • Christchurch, New Zealand
Posted 04 February 2009 - 06:10 PM
Sanjay Sami
Thats what I did - and saved a real bundle. Got 5 arms out of 1 length of stainless. Used Grip heads from Kupo which are very well made and cheap in New Zealand.
#8 Daniel Wallens
Daniel Wallens
  • 214 posts
  • Grip
  • New York City
Posted 05 February 2009 - 03:29 PM
Speaking of, does anyone know the:
-OD
-ID
-Wall
-Steel alloy
-Grade (Austenite/Ferrite)
used in c-stand arms? just curious...
#9 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
Posted 06 February 2009 - 10:31 PM
-OD
-ID
-Wall
-Steel alloy
OD is 5/8th of an inch. That size is standard for many things (Cardellini, Baby pin included)
Wall Thickness - i use 1.5 mm stainless. it gives me a lot of strength for rigging as well. I use 5/8th clamps for rigging some stuff also.
ID ... ID = OD - (Wall thickness x 2)
Regular stainless steel works well.
Sanjay Sami
#10 Michele Peterson
Michele Peterson
  • 148 posts
  • Film Loader
  • Burbank, Ca
Posted 06 February 2009 - 11:50 PM
Having a head that can be removed or slide up and down the length of the arm is something highly desired. It comes in very handy when rigging in tight spaces. Out of the big grip manufactuers, American does have it, Norms does not, but I don't recall about Matthews and Modern.
#11 Salil Sundresh
Salil Sundresh
  • 101 posts
Posted 08 February 2009 - 10:32 PM
Sanjay Sami
Just curious, where did you manage to find this stainless steel pipe? I searched home depot, lowes, and menards in the chicago area with no luck. The only thing I found that was proper size is a copper pipe, but I'm afraid it may not be strong enough. Any suggestions would be greatly appreciated.
#12 Daniel Wallens
Daniel Wallens
  • 214 posts
  • Grip
  • New York City
Posted 09 February 2009 - 12:00 AM
Doh! Of course. Duh. I guess i wasn't thinking when I posted... just went ahead and listed all the variables.
Thank you. Is 1.5mm the industry standard for arms? Or do you use this especially for added stability?
Again, duh on my part. Sorry. :)
This part I'm not so sure about. What do you mean by "regular"? Stainless comes in grades of T321, T316, T304 most commonly, and there are others as well (in addition to various fabrication processes). Here's a good reference on just the different grades:
http://store.microgr...reference.cfm#1
Is there one that is more "regular" than all others?
Salil,
I am far from an expert on steel manufacturing and distribution, but generally standard retailers are not the best place to get what you're looking for. A stainless fabrication supplier would be best. Depending on where you are located, here might be a good place to start looking:
http://www.zycon.com...eel-Tubing.html
#13 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
Posted 09 February 2009 - 09:32 AM
Hi Salil,
I'm afraid I will not be able to help you on that one ... I live in India, and here it is a very common OD (used to make Autorikshaw/ tuk tuk frames ). I cant imagine it would be that difficult to find in America (you still use imperial measure not metric)
Please DO NOT use copper. It is extremely ductile (bendy). Use mild steel if you have to, but it will rust.
#14 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 09 February 2009 - 10:36 AM
There is no such thing as "regular stainless steel". It comes in several grades (alloys) 316, 440, etc., each having their own properties and varying costs. Try the metal or steel category in your local yellow pages or Metal Supermarket. They have locations in most major US cities http://www.metalsupe...m/msc-home.aspx Or try an on-line supplier like speedymetals or onlinemetal. I'd think about using aluminum tubing for cost reasons.
#15 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
Posted 10 February 2009 - 03:02 AM
[quote name='JD Hartman' date='Feb 9 2009, 10:06 PM' post='272550']
You are right. My meaning however is, for a C stand arm, the tensile requirements of the material are of no significance within the larger family of "Stainless steel". Hence the term "regular" was used when I should have said "any stainless tube that you find with an OD of 5/8th of an inch"
The alloy you buy within the stainless family will not affect your performance ;)
#16 JD Hartman
JD Hartman
  • 1764 posts
Posted 11 February 2009 - 10:41 AM
Exactly, but the alloy will affect the price, so if you must have stainless steel grip or gobo arms, pick 303 or 316. The wall thickness will determine the arms rigidity, the ones I measured varied between .080 and .100
#17 JD Hartman
JD Hartman
  • 1764 posts
Posted 12 February 2009 - 03:27 PM
Another option if surface rust is a big concern. Contact a local fabricator of clothing and display racks. They typically buy tubing buy the truck load. They may have 5/8 od tubing with a chrome plate finish. All you would need to do is cut it to length and plug the end with plastic caps for a professional look.
#18 Salil Sundresh
Salil Sundresh
  • 101 posts
Posted 23 February 2009 - 09:09 AM
Thank you to everyone for your input. I'm still having some difficulty finding an apropriate diamter tube. Are there any online stores where I could order the appropriate tube that anyone has to suggest?
#19 JD Hartman
JD Hartman
  • 1764 posts
Posted 23 February 2009 - 02:33 PM
Try the Yellow pages, steel supply, pipe and tubing, etc. On line: Online metals, metal warehouse, metals supermarket, etc. But expect to pay a higher price per foot (plus shipping) than a local supplier.
#20 Salil Sundresh
Salil Sundresh
  • 101 posts
Posted 19 March 2009 - 06:38 PM
Sanjay Sami
I was wondering if anyone had a ball park range I should pay per foot for 5/8" stainless steel tube for using as a gobo arm? Chepeast place I found locally was $75 for 20ft (minimum 20ft purchase). So $3.75/ft. Seems like a bit much?
