Can anyone tell me how this is done?
14 replies to this topic
#1 Shawn Fields
Shawn Fields
Posted 05 February 2009 - 02:49 AM
I'm very curious how these effects in this commercial were done. It sort of looks like tilt/shift but too extreme.
#2 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 05 February 2009 - 05:48 AM
It looks to me like some of the soft focus shots may have been done with vaseline or KY Jelly smeared on a clear filter in the matte box. You can get very distinct edges between soft and sharp using this technique, depending on how thick you smear the jelly and where. It doesn't take much at all to make the image completely soft.
#3 Piotr Ciacka
Piotr Ciacka
  • 17 posts
Posted 05 February 2009 - 09:21 AM
This site says it was shot by Philippe Le Sourd, not Doyle.
#4 Thom Stitt
Thom Stitt
  • 68 posts
  • Vancouver
Posted 05 February 2009 - 06:02 PM
Wow, that was incredibly gorgeous from beginning to end. I also thought of vaseline for the half-blurred effect - Dylan Macleod at the reduser forums suggested it might be waterglass (a sheet of rippled glass) used in front of a long lens.
I'd love to get all the details though - camera, lenses, etc. Really a gorgeous little film - except for the cut-cut-cut-cut-cut that doesn't separate it much from every other spot for every other product in the world - and when "Luis Vuitton" appears onscreen at the end, it seems doubly ridiculous and absurd after all of the visual poetry that preceded it. It might be an example of making your spot TOO good!
#5 Mitch Monthie
Mitch Monthie
  • 2 posts
Posted 05 February 2009 - 09:17 PM
Most likely it was done using some sort of tilt lens like a Lensbaby, made by LENSBABY, INC.
http://lensbaby.com/index.php
Vaseline is an old school trick.
Other films you could see something of the sort (not sure if they use a lensbaby) includes Deakin's Assasination of Jesse James by the Coward Robert Ford, and Kaminski's The Diving Belle and the Butterfly
Of course, Deakin's could have used vaseline as well. However the effects look pretty heavily controlled. Yet, he is a god so not that he couldn't have done what he did with vaseline, I'm just assuming he used a special lens. :D
Anyone with anymore info?
-Mitch Monthie
Aspiring DP
#6 Shawn Fields
Shawn Fields
Posted 05 February 2009 - 09:40 PM
I remember reading an interview somewhere with Bruno Aveillan and I thought he said it was shot by Doyle. Maybe a collaboration?
-The vaseline is an old trick but still effective, for diffusion, but could it really blur that much?
-would a lensbaby be that sharp in the areas that aren't blurred?
#7 Chris Keth
Posted 06 February 2009 - 12:39 AM
I don't think it's a tilt-shift or a lensbaby. Those just move the focal plane around. There is still a gradual transition to being out of focus in 3D space. This is a pretty sharp line from sharp to blurry. My bet is on KY on a flat. Vaseline looks more streaky. With KY, if you're careful, you can get it on there without any particular direction to the application to create linear smears. Use very little.
#8 Shawn Fields
Shawn Fields
Posted 06 February 2009 - 01:20 AM
Thank you Chris! KY seems to have that magic "touch".
#9 Pete Stone
Pete Stone
  • 2 posts
Posted 30 January 2010 - 10:05 PM
See Cokin Filter #217.......
Pete
#10 Mahmoud Samir
Mahmoud Samir
  • 8 posts
Posted 19 January 2014 - 07:50 AM
Hi guys,
I am an amateur and newbie in cinematography.
 what KY means?
#11 John Holland
John Holland
  • 2273 posts
  • London England
Posted 19 January 2014 - 07:58 AM
KY is a water based lubricant found in Pharmacies and Sex shops!
#12 Daniel Mimura
Daniel Mimura
  • 10 posts
  • Seattle WA
Posted 30 January 2014 - 11:37 PM
Wow...that much KY and Vaseline... I can just see the filmmakers buying it at the grocery store. "this is for a Louis Vuitton commercial?  Yeah, right."
Edited by Daniel Mimura, 30 January 2014 - 11:38 PM.
#13 Mei Lewis
Mei Lewis
  • 348 posts
  • UK
Posted 23 February 2014 - 03:23 AM
Yes, they can be very sharp in the area that's in focus. This is a 1:1 crop of a frame I shot.
#14 Mei Lewis
Mei Lewis
  • 348 posts
  • UK
Posted 23 February 2014 - 03:25 AM
And some of the elliptical bokeh in that video looks very much like a lensbaby too.
Not sure if lensbabys were available back then though, so it's probably a different lens with a similar effect and a mix of a bunch of other techniques.
#15 Mei Lewis
Mei Lewis
  • 348 posts
  • UK
Posted 23 February 2014 - 03:30 AM
Elliptical bokeh from the film.
Maybe it's simply freelensing?
Edited by Mei Lewis, 23 February 2014 - 03:31 AM.
