30 fps - 2:1 4k?
#1 Matias Nicolas
Matias Nicolas
  • 157 posts
  • Buenos Aires, Argentina
Posted 09 February 2009 - 07:47 PM
sorry, I have 2 little doubts :
1..... Can you set your project at 30fps 4K , 2:1 or 16:9 ?
...and,
2...........what is the difference if you set your project 4K 2:1 25 fps, and then you change the value speed in the menu, in varispeed option to 30 fps ? its the same? what changes ?
thanksss
#2 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 09 February 2009 - 09:26 PM
The max frame rate in Redcode 36 in 4k 2:1 when recording to 16gb cards or the drive is 30fps. The way you set your projects base frame rate will impact timecode and audio. Varispeed will disable audio.
Kevin Zanit
