Canon 1014 xl-s Shutter angel
11 replies to this topic
#1 Gustav Bergstrom
Gustav Bergstrom
  • 6 posts
Posted 11 February 2009 - 04:11 PM
Hi, I've just bought an Canon 1014 XL-S camera that seems to be quite OK, but there's one thing that I don't understand. When I switch between the sun and the window symbol (that change the shutter angle from 150°/220°) I can hear that a motor or something like that starts an makes an adjustment. But: when i look at the exposure dial inte the lens, the aperture don't change. When I adjust film speed or the button for tungsten/daylight, the aperture setting changes as it should. I suppose that a 220 angle would make a difference for maby 2/3 step on the aperture scale. The fading works just fine. Could it be that the button for the shutter angle works (a sound is heard when moving it) but ther's something wrong in the communication between shutter angle adjustment and aperture sdjustment? Is there anybody that hade experinced the same problem or just happends to know what could be wrong (if ther's something wrong).
Many thanks in advance
Gustav
#2 andy oliver
andy oliver
  • 263 posts
  • uk
Posted 11 February 2009 - 06:10 PM
Hi, i've just operated my shutter angle switch, whilst looking thru the viewfinder on my 814xl-s, yes the iris does change, about a 1/3 of a stop, assume your exp lock dial is set to auto? and you are looking thru the viewfinder whilst operating the switch....
#3 Alexander Zabotkin
Alexander Zabotkin
  • 26 posts
Posted 11 February 2009 - 07:31 PM
Hello
Try to check the viewfinder indication when you switch it
These Canon's have a full digital circuit, so problems with exposure correction at switching the shutter dial are very improbable...
#4 Gustav Bergstrom
Gustav Bergstrom
  • 6 posts
Posted 12 February 2009 - 02:05 AM
Yes, the camera is in Auto mode and I look thru the viewfinder but the dial doesnät move. If I change the exposure compensation dial or the sun/tungsten switch, the dial does move.
/G
#5 Gustav Bergstrom
Gustav Bergstrom
  • 6 posts
Posted 12 February 2009 - 02:13 AM
I've just checked the stitch again in full daylight, and YES i't does move (about 1/3 stop)! Thanks!
#6 Alexander Zabotkin
Alexander Zabotkin
  • 26 posts
Posted 12 February 2009 - 03:30 AM
Good luck with the camera!
Best regards
#7 Gustav Bergstrom
Gustav Bergstrom
  • 6 posts
Posted 12 February 2009 - 03:57 AM
Thank you! Seems to be a very good camere and I really like the zoom. The rubber hood is missing so I must buy a new one so I can use filters (am I right here), cause I plan to shoot the fast Tri-X.
#8 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 12 February 2009 - 07:05 AM
Great camera. You should always use a lens shade even without filters. A set of ND filters is useful for filming in general and especially with fast emulsions such as Tri-X and 7218 color negative films.
#9 Gustav Bergstrom
Gustav Bergstrom
  • 6 posts
Posted 12 February 2009 - 07:33 AM
I see. Du you thing I can by a ordinare Canon rubber hood 67 mm, like this one:
Canon rubber hood?
In the instruction manual I find information about a 67 mm rubber hood and then 72 mm filters. I found a filter kit with ND filter.
#10 Alexander Zabotkin
Alexander Zabotkin
  • 26 posts
Posted 12 February 2009 - 09:54 AM
Canon rubber hood?
I think this should work fine. Maybe you can also look at Tiffen and other supplies of wide-angle hoods.
#11 Miguel Loredo
Miguel Loredo
  • 143 posts
Posted 12 February 2009 - 02:00 PM
You don't need the rubber hood to put filters. You can attach them directly to the lens (67mm diamteter instead of 72mm with the hood). My 1014 XL-s doesn't have the rubber hood either ;)
#12 Gustav Bergstrom
Gustav Bergstrom
  • 6 posts
Posted 12 February 2009 - 02:27 PM
Thanks for all help! I ordered a rubber hood and filter to protect the lens for sun, I think that could be a good idea.
