RED Start/ Stop cable
#1 Joel Phillips
Joel Phillips
  • 9 posts
  • Seattle
Posted 11 February 2009 - 05:47 PM
I realize this may not be in the correct division to post but I will try anyhow. Does anyone know what the pin configuration is for a RED start/stop cable? Also, which port do you suggest using- the 4pin lemo ports on the rear of the camera or the aux port on the front assistant side of the camera. Any information would be helpful. Thank you.
#2 Mike Thorn
Mike Thorn
  • 64 posts
  • Grip
  • Cleveland, OH
Posted 11 February 2009 - 07:00 PM
The 4-pin rear LEMO ports are 12v auxilary power. I'm not certain what function the aux port provides...it's been too long. :(
However, I know that certain remote focus units can do start/stop, so that's presumably the port of call?
#3 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 11 February 2009 - 07:02 PM
I can't help with the pinouts, although I'm pretty sure they're posted at on the steadicam forum.
You can use either the aux port or the 4 pins on the back. I use the aux port with my preston, but I know some people use the 4 pins.
#4 Marque DeWinter
Marque DeWinter
  • 117 posts
  • Digital Image Technician
Posted 12 February 2009 - 08:59 AM
On the Top Aux is the port and if I remember pin 1 is top and pin 3 is start, but don't hold me too that..my memory on it isn't that great either. Search on reduser.
~Marque
#5 James Rydings
James Rydings
  • 38 posts
  • Los Angeles, California
Posted 15 February 2009 - 11:45 PM
I did a commercial last week on the Red which the package was rented from HC Camera Rentals. They had a start stop cable that plugged into the 4pin lemo's in the back. Im not sure of the pin configuration but I am sure they would know.
