HDcam capture to FCP via Blackmagic HELP!!
#1 Stephen Murphy
Stephen Murphy
Posted 19 February 2009 - 09:10 AM
Im trying to capture a HDcam tape to FCP 6 using a Blackmagic HD extreme card and a HDW -M2000P deck and im having a problem.
The deck is fine, FCP is fine and Ive used the Blackmagic card to capture plenty of PAL 8 and 10 bit tapes but this is my first time trying to capture any HD footage.
No matter what HD setup i use in FCP i cannot see any HD footage in the log and capture screen.
If i use an SD setup like PAL - 10 bit uncompressed, i can see and capture the footage that way but then im not taking full advantage of the HDcam resolution.
Ideally id like to be able to capture at ProRes HQ quality.
It sounds to me like a setup/settings issue but ive been through all the FCP setups and still have had no luck, so it might be a blackmagic settings issue? - I've only got the HDcam deck for the day so if anyone can help I'd appreciate it.
#2 Stephen Murphy
Stephen Murphy
Posted 19 February 2009 - 10:08 AM
Solved Thank you!
#3 Keith Mottram
Keith Mottram
  • 824 posts
Posted 19 February 2009 - 10:09 AM
been a long time since i used a BM card (had too many problems with them in the past), but I would check your BM control panel which is either in system preferences or in the aplication folder i think. hope this helps.
after i posted this your reply popped up. for future reference what was it stephen?
#4 Stephen Murphy
Stephen Murphy
Posted 19 February 2009 - 11:15 AM
For future reference never let a DP near a computer unless its an xbox.
I had the bnc cable plugged into SDI instead of HD-SDI. Hence why FCP was seeing a downconverted SD image and not a HD image. Page 1:-)
#5 Phil Rhodes
  • 12163 posts
Posted 19 February 2009 - 06:18 PM
Noted for future use.
