Dynamic Range of 23 Stops
36 replies to this topic
#1 John Sprung
John Sprung
  • 4635 posts
Posted 23 February 2009 - 08:21 PM
Let's see if I can upload these pictures:
#2 John Sprung
John Sprung
  • 4635 posts
Posted 23 February 2009 - 08:32 PM
OK, so here's a test image and a blowup of a small portion of it. The 500 Watt halogen broad is the only light in the room. This is from the Thompson GV Infinity, the claim is that it has a dynamic range of 23 stops. You can see detail in the coils of the filament and in the shadows lit only by bounce off the wall behind the camera. This was shown at HPA last week.
#3 Adrian Sierkowski
  • 7373 posts
Posted 23 February 2009 - 08:55 PM
That certainly is damned impressive... if a bit lifeless of an image....
Who ever chooses what to put into these test frame anyway?
Still... 23 stops....
Though looking over the specs I wonder what recording time is like on the machine and I'd also love to see what, say, A Resolve could do with that....
#4 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 23 February 2009 - 09:10 PM
Something doesn't smell right here.
Up until now, the very best video cameras you can get have a dynamic range of something less than 14 stops, and "range" is very much determined by how much lowlight noise you are prepared to put up with, (or put up with having artificially removed).
So, we now suddenly have a camera with another 9 stops of dynamic range?!
I could believe 2 or 3, but nine?!
The sensors have overnight gotten 512 times better in performance?
What's the catch...?
#5 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 23 February 2009 - 09:25 PM
If you lit the chart with more light than you'd ever light a chart with or could bear, you could easily do that trick. This shot is clearly not what it seems to be. You can clearly see the reflection of a light coming from the right of the camera that is lighting the chart. It creates a defined shadow and creates light through the bottle of wine that is represented on the wall behind the bottle. Bounced light and not do that. Or if you had the broad on a dimmer along with the additional light that is lighting the chart you could do that same trick. And that same light that is lighting he chart is seen as speckled reflections in the bottles to the left and just above the open face. And if you try to quickly blow up the open face fixture, you can see that it is not the same shot as the second shot claiming to be a blow up. Detail is just not there in the wide shot. And notice the hard shadow to the left of the open face (it's barn door creating a shadow). If that open face was lighting itself and the light was reflecting of the wall behind the camera the shadow wold not be nearly 45 degrees camera right as it is nor below the fixture as would be created by a source light which is higher than the open face as it is. . Incident reflection off the wall would make it more head on. Clearly this is a parlor trick. It would easily fail a forensic light test based on all the flaws in the shot based on the claim. I could easily recreate this shot and demonstrate that it is a fake using just a bit of math based on the shadows to not only tell you where the source of light in the room is but at what height, and even what distance based on the sharpness of the shadow.
#6 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 23 February 2009 - 10:44 PM
If you lit the chart with more light than you'd ever light a chart with or could bear, you could easily do that trick. .
Or you could just go and shoot it out in your back yard at midday :D
#7 Chris Keth
Posted 24 February 2009 - 12:34 AM
Is that much dynamic range a good thing? Can you decrease the dynamic range in camera? Think of lighting an interior for that thing. Say you needed a baby for a kicker on an F900, on this thing you may need a 10K to do the same thing without a huge increase in contrast in post. It seems to me that lighting packages would have to go up to be able to light with any decent contrast since, I assume, large increases in contrast in post would come with a large amount of noise.
#8 Karel Bata
Karel Bata
  • 487 posts
  • London - a rather posh bit
Posted 24 February 2009 - 08:01 AM
It could be 2 exposures blended together. Shouldn't that light source create more lens flare? And why is it so green? The test engineers at Thompson don't know how to white balance...? And it's a tungsten source.
#9 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 24 February 2009 - 11:54 AM
White balancing in camera would loose loads of dynamic range, it's the same with the Viper.
Stephen
#10 John Sprung
John Sprung
  • 4635 posts
Posted 24 February 2009 - 12:28 PM
Before we even get that far, of course out here in the real world today, we don't have any means of storing or displaying 23 stops of range. If they're really working with that kind of image data, they must be inventing a way to store it, and showing us what they extract from that in these JPEG's.
The other light might possibly be bounce off of something (the operator's shirt?) much closer than the back wall of the room. How they squeeze the big range into the JPEG could have something to do with that.
These are the Thomson/Grass Valley folks. I've known some of them for years, and they've been in the biz for like half a century now. The guys I've known from those companies have always been honest and competent.
#11 John Sprung
John Sprung
  • 4635 posts
Posted 24 February 2009 - 12:30 PM
Yes, that's likely how it works. The camera has a CMOS chip (or chips). Perhaps it has photosites of different sizes for two or more sensitivity ranges, a sort of simultaneous bracketing. The other theory is that the chip somehow polls for saturation during the exposure, and goes by how long it takes to get there. If so, it might have some strange motion issues.
#12 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 24 February 2009 - 02:42 PM
The scene's lit, and if you stop down & ND enough you can get detail in the filament and rear reflector of any light. So what's the big deal? Do we have any details about how the shot was done or manipulated in post?
Ideally, shouldn't the original image be correctly exposed for the chart, with the light itself 11 stops over, and perhaps another chart in frame 11 stop under? Then two corrected images, 1 printed up and one printed down to show us images with reasonable detail?
#13 Will Earl
Will Earl
  • 385 posts
  • Wellington, NZ
Posted 24 February 2009 - 06:16 PM
John, I loath to question such a definitive statement from you, but I would dare say there are plenty of image formats quite capable of storing that much range. To display that entire range all at once is another matter and would require some sort of tone-mapping operation to compress it all into a 0..1 space, of which most tone-mappers tend to produce rather horrible looking images.
I'm going to remand sceptical for now, but if it is what they say it is - then it has the potential to be very interesting.
Edited by Will Earl, 24 February 2009 - 06:17 PM.
#14 Karel Bata
Karel Bata
  • 487 posts
Posted 24 February 2009 - 08:35 PM
However it was done, I don't get how the gray scale can be gray, while the rest of the scene, like the paper cups, comes out green...
Rather negates the point of a gray scale! :lol:
#15 Phil Rhodes
  • 12171 posts
Posted 24 February 2009 - 08:50 PM
Drivel.
The bottle at left is casting a sharp shadow on the wall behind it, from a source considerably above its own level. There is clearly additional light involved.
It could be green if they've taken it directly off the chips, I suppose.
#16 A. Whitehouse
A. Whitehouse
  • 267 posts
  • Melbourne
Posted 25 February 2009 - 03:43 AM
Who has that much cereal? 23 flavors of Cruesli more likely...
#17 Adrian Sierkowski
  • 7373 posts
Posted 25 February 2009 - 09:07 AM
It's the doll that worries me... those skin-tones don't look natural ;)
#18 Aasulv Wolf Austad FNF
  • 1 posts
Posted 28 February 2009 - 03:47 PM
Thanks for posting the pics. Interesting that Thomson GV is now showing these High Dynamic Range pics taken with the Infinity camera. Is this the same demo they've been showing before where they control exposure time in each CMOS pixel individually and hence can capture very high dynamic range?
Next thing to see is how this affects motion....
#19 David Williams
David Williams
  • 69 posts
  • Melbourne, Australia
Posted 02 March 2009 - 05:45 AM
John Galt is working on a HDR sensor, with up to 6 exposures per pixel in one pass.
Info is nearer the end.
http://magazine.crea...uture-of-pixels
#20 Thomas James
Thomas James
  • 844 posts
Posted 02 March 2009 - 01:33 PM
Yes I believe that John Galt's 36 megapixel sensor is called the Dynamax and it produces 2K at 4:4:4
