High School Event
#1 Elizabeth Starr
Elizabeth Starr
  • 1 posts
Posted 26 February 2009 - 03:44 PM
Questions re: High School Event/hallway lighting
We plan like to cover overhead fluorescents with Apollo gels - Island Blue or Ozone Blue (maybe both, alternating).
1) What colors/material would work well under this lighting? We plan to line the halls almost completely with either mylar, metallic mylar, polyvinyl or gossamer. Would silver be a good neutral choice under the blue light? Should we stick with white or cream?
2) We also want to run solid color tape along either the floors or over the wall material, to give each hallway a separate color identity as a subway line. We'll need royal blue, orange and forest or kelly green (not yellow-green). Can anyone recommend an adhesive tape that either glows in the dark (all-night grad party, 8 hours) or is otherwise able to be seen under the bluish light that the gel-filtered overhead fluorescents will produce?
3) Can anyone recommend a source for adhesive sheets of reflective material that can be cut into desired shapes?
Look forward to answers - desperately seeking input!
#2 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 27 February 2009 - 05:27 AM
Well, "good" is a relative term, what are you trying to achieve in the look, I mean what are you going for? Sometimes disgusting might be good for what you might be trying to achieve, see what I mean?
I don't know of any glow in the dark tape but maybe reflective safety tape might work if you hit it with strategically placed slashes of light.
I would check hobby supply stores
Hope it helps a little.
Edited by James Steven Beverly, 27 February 2009 - 05:29 AM.
#3 Ralph Keyser
Ralph Keyser
  • 120 posts
Posted 27 February 2009 - 04:49 PM
1) This one's a little hard to answer without knowing more about the look you are trying to get. How did you make the choice on the gels?
2) There are several types of gaffers tape that glow in the dark or glow under blacklight, but all the glow-in-the-dark ones that I've seen are that yellow-green color. They also make gaff tape in all sorts of neon colors. Some of those fluoresce well under blacklight. I think it's going to be hard to render colors accurately under the lighting scheme you have proposed.
3) You might consider one of the temporary spray mount adhesives for sticking your reflective material to surfaces. An art supply place should have them.
Best of luck with your project!
