How accurate is a light meter?
7 replies to this topic
#1 Karel Bata
Karel Bata
  • 487 posts
  • London - a rather posh bit
Posted 08 March 2009 - 10:03 AM
I remember reading some years ago in Anton Wilson's Cinema Workshop that light meters (back then) had to be accurate to within + or - half a stop at the point of manufacture. That was the spec. and it meant that you could have two side by side giving readings that were a stop apart (one +half and the other -half) yet both would be regarded as accurate!
Has that half stop standard changed? If so, to what?
And how do you guys check your meters for accuracy?
#2 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 08 March 2009 - 02:26 PM
Modern Meters (should) be calibrated within a 1/10 of a stop. Meter calibration techs such as Quality Light & Metric in the USA do the adjustments.
#3 Chris Keth
Posted 08 March 2009 - 07:06 PM
I just check mine against full sun and see if it's reasonable. I have it calibrated fairly regularly, though.
#4 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 08 March 2009 - 07:21 PM
Along with what Mr. Keth has mentioned.. it is common to have a meter party before the first shot.. everyone stick your meter in the middle and see what the average of readings is... if there is a discrepancy between my gaffer's meter and mine.. I go with mine because I (personally) carry two Ambient Meters and will check them against each other prior to arriving on set as well as light an 18% Gray Card.. measure it with an Ambient meter and then check my Spot Meter against that...
..and send them to Quality Light & Metric every year or so.
#5 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 10 March 2009 - 09:56 AM
The newer Sekonic meters have a adjustment function where you can dial in your meter to match another one, in tenths of course. I've done this before when shooting 2nd unit. Very handy.
#6 Karel Bata
Karel Bata
  • 487 posts
Posted 10 March 2009 - 10:17 AM
Time I upgraded from my Weston V. Damn fine meter. :D
#7 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 10 March 2009 - 10:55 AM
Ditto!
They also calibrate and repair color meters, last year they brought my Minolta Color Meter II back from the jaws of death.
Quality no longer maintains a store but the lab is still in LA. The address below is for a Mail and More that Quality picks up from, and delivers to, twice daily. When you talk to him directly, be prepared for a borderline command of English. Sometimes it takes a little effort to make certain he is understanding exactly what you're saying.
Quality Light Metric Co.
7095 Hollywood Blvd. No. 550
Hollywood, CA 90028
USA
Tel: 323 467 2265
#8 Serge Teulon
Serge Teulon
  • 757 posts
  • London UK
Posted 10 March 2009 - 11:34 AM
Does anyone know of a place to calibrate meters in the UK?
