Where have all the neg cutters gone?
31 replies to this topic
#1 GeorgeSelinsky
GeorgeSelinsky
  • 718 posts
Posted 09 March 2009 - 10:34 AM
Hi all!
I've been in hybrenation from the film world for a while and I've reemerged to find less labs. Seems like film is not doing much better than the stock market, lol.
I've got a feature and I'm trying to get a flash-to-flash pull done so I can minimize the expense on my HD transfer. I'm very reluctant to take my negative out of NYC, I've got 78 flats of 35mm and I can't afford to think of anything getting lost on fedex.
A quick Google search and a few phone calls revealed to me that NYC's big negative cutters, Noelle Penraat, N&D films, are no longer in existence. I only found one guy so far who does it, and it'd be nice to have more than one choice.
I'm also contemplating doing this myself possibly, to save money. Anyone has any helpful advice on what kind of hot splicer to use, and how many weeks this might take for a 2 hour show? I've got about 2000 total edits, with the flash to flash I'm imagining that aught to be less.
- George.
  • 20069 posts
Posted 09 March 2009 - 10:39 AM
I think they all got on a boat like Frodo and Gandalf at the end of "Return of the King"...
#3 GeorgeSelinsky
GeorgeSelinsky
  • 718 posts
Posted 09 March 2009 - 11:02 AM
Lol, yeah I wouldn't be surprised David :)
Btw, what do people do these days who shoot on film? Do they just get the uncorrected dailies and then go back to the uncut flats for the final transfer and go by keycode and autoconform? I was told that without cut rolls you have to allow twice if not three times the amount of time it would take with cut rolls.
Any advice here?
- George.
Edited by GeorgeSelinsky, 09 March 2009 - 11:02 AM.
#4 David Mullen ASC
  • 20069 posts
Posted 09 March 2009 - 11:25 AM
It's been a tradition for some time to avoid chopping up camera rolls if at all possible.
Even back in 1993, when I shot my first 35mm feature that was cut on an AVID, with video dailies, it was important that I had entire camera rolls printed when I wanted to see something projected, or else the roll would be cut up into a printing roll.
Yes, it creates longer rolls for the neg cutter to go through (but probably fewer total), but you reduce the risk of mishandling and losing bits by avoiding earlier neg cuts. Sometimes neg cutters have a harder time when the shot they need is on some other printing roll that isn't in the same place as the rest of the footage.
Anyway, neg cutters have been used to going through whole camera rolls for decades now.
As for doing a D.I., right now the idea is that you use your EDL in order to find the shots on the camera rolls, scan those, and then create an edited digital master using autoconform.
Or if you are doing an HD D.I., you probably transferred all the footage to 10-bit 4:4:4 HDCAM-SR as a flat "one light" (and made color-corrected dailies from that), so you go back to those tapes and online from that.
#5 K Borowski
K Borowski
  • 3905 posts
Posted 09 March 2009 - 12:24 PM
Well, at least when your life's work becomes obsoleted overnight, as a negative cutter, you have a convenient means of escape: a razor blade :(
On a more serious note, not only with TV shows being pushed digital, but with the DI and HD transfer, it seems that the need to actually cut film, rather than telecine the whole batch, has really cut into their business.
#6 GeorgeSelinsky
GeorgeSelinsky
  • 718 posts
Posted 10 March 2009 - 09:25 AM
Indeed it seems that times have changed...
I've basically figured out that if I trim the negative flash to flash, I can save over 50% on transfer time. I spoke to one neg cutter and I realized that it just isn't worth getting the flash to flash done professionally when you count the cost of doing it. For my film, I priced it out to being $15 grand. That's how much they used to charge to match a 1000-1500 cuts feature (mine is at 2200).
This leads me to the only other solution - do the flash to flash pull myself. Yeah, it's a lot of time I know, but the cost savings is worth it.
Has anyone any pointers on how to do it? Any recommended hot splicer models? Film management techniques? I'd appreciate any advice. So far the web seems to be sparse on the subject.
Thank you very much in advance!
#7 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 10 March 2009 - 10:35 AM
I believe Spielberg has the last one.
#8 John Brawley
John Brawley
  • 834 posts
  • Atlanta Georgia
Posted 10 March 2009 - 04:14 PM
Hi all!
Not that it helps but same here. I was fantasising about shooting 35mm anamorphic with a traditional non DI finish for a recent job (went SI-2K with an anamorphic adaptor instead). The lab laughed at me and said they had mothballed their hazeltine a year ago because no one had used it for a year.
jb
#9 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 11 March 2009 - 05:34 PM
Where are you now John? Hazeltines haven't been used for yonks anywhere in Australia. The lab I was with until recently (you know its name) still uses its Colormaster regularly.
But most (not all)of the neg matching companies in Sydney are now closed down. If negative is cut, then it's full takes ("flash to flash"), which still requires careful handling but not the same degree of precision that is needed for a frame-accurate final cut neg.
Clean conditions, well-aligned rewinders, fresh film cement and a calm temperament are as important as a good splicer.
#10 John Brawley
John Brawley
  • 834 posts
  • Atlanta Georgia
Posted 11 March 2009 - 05:46 PM
Hey Dominic !
So lovely to hear from you. Hows the time off ? I hope you have some secret plans to do something else ? I heard a vicious rumour about another mob (RS) re-opening a lab up you know where ???
I was talking of the melbourne branch of that mob. last time i did an optical finish DOWN THERE i used the hazeltine ;-)
jb
#11 K Borowski
K Borowski
  • 3905 posts
Posted 11 March 2009 - 05:53 PM
Gee Dominic, what happened?
#12 John Brawley
John Brawley
  • 834 posts
  • Atlanta Georgia
Posted 11 March 2009 - 06:28 PM
I won't presume to speak for Dominic but that Lab recently became a part of a much larger American lab.
jb
#13 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 11 March 2009 - 08:15 PM
Their machine is a Colormaster.
Some Colormasters are the just the Colormaster image chain built on a Hazeltine chassis (and sometimes known as a "Hazelmaster" - but the digital colour correction is all Colormaster.
For clarification, the Atlab group of labs which included Atlab in Sydney and Auckland NZ, and Cinevex in Melbourne (referred to by JB as "down there"), was recently acquired by Deluxe. It's now rebranded as Deluxe Australia (which includes EFILM Australia in the same building), Deluxe Melbourne and Deluxe Auckland. I'm no longer there.
There is talk of the Warner Bros Village Roadshow studios in Queenlsland reopening the loss-making lab that Atlab closed down there (on the studio lot) last year. I guess it would just be a simple process-only front-end service again though.
#14 John Brawley
John Brawley
  • 834 posts
  • Atlanta Georgia
Posted 11 March 2009 - 09:09 PM
My mistake. Im sure it was or perhaps it was the chasis version. It was a fair few years ago. They were the only lab i've ever done film finishes at, and that's the only brand of colour grading that I know from that process so i figured it must have been what they used !
I suspect RS are looking to set that up to prop up the studios they own there ? No lab in the state of QLD makes the studio's look a bit useless right ?? I guess it's actually about keeping the theme park that's ATTACHED to those studios going. Movieworld where there's no one making movies doesn't really make a lot of sense !
jb
#15 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 11 March 2009 - 11:41 PM
Not really.
How many states in the USA have thriving (though small) film production, with rich state incentives, but no lab? What about the activity in South Australia - about the most prolific growth of any Australian state in the last year or two.
If you shoot film then the airport isn't far away, bringing larger facilities in Sydney within reach. If you shoot digital (which is the case for more and more of the offshore work that the Queensland studios are seeking to attract) then a lab is irrelevant.
I think it's more complex. Queensland cinematographers were NOT HAPPY when Atlab closed. Their bread and butter is commercials, and many of them like to shoot film. No lab on a quick and snappy commercial shoot is a bigger issue than no lab on a feature. So TVCs go digital, upsetting those cinematographers. Are the studios trying to improve the situation for them? Why?
#16 Simon Wyss
Simon Wyss
  • 1491 posts
  • Basel, Switzerland
Posted 12 March 2009 - 12:34 PM
Hi, George
Had you shot on polyester base film and not in CinemaScope the negative assembly were a fun thing to do. Welding machine, you know.
I should come to NYC and do the job with Hammann equipment. 2000 splices sounds like five weeks. I am used to work exactly and I have a soft touch.
#17 K Borowski
K Borowski
  • 3905 posts
Posted 12 March 2009 - 01:46 PM
Simon, if you came to NYC and did cutting, you could definitely make money. IDK about B&W neg. That particular form of filmmaking "Jumped he Shark" over 30 years ago. . .
What was the last theatrical B&W film release you can think of? Howabout the last B&W television show.
I know some uneducated fools who say "Oh, I wouldn't bother seeing a B&W film."
I am pretty sure that neg. cutting is dead for television now though.
#18 K Borowski
K Borowski
  • 3905 posts
Posted 12 March 2009 - 01:51 PM
George, I'd say it depends on what you've shot, but I would say to stay as far away from 4-perf. as possible I've seen PROFESSIONALLY cut anamorphic films, like "The Alamo" where you could see a faint line every time they changed shots. Maybe the gate was slightly out of alignment, but this is unlikely. This was/is a Union run theatre.
#19 Marc Alucard
Marc Alucard
  • 176 posts
Posted 12 March 2009 - 06:49 PM
What was the last theatrical B&W film release you can think of? .
David Lynch's "The Elephant Man" and "Eraserhead".
More recently Cory McAbee's "The American Astronaut"
#20 David Mullen ASC
  • 20069 posts
Posted 12 March 2009 - 07:31 PM
"The Good German" was the last one I saw, I think. Before that, "The Man Who Wasn't There". There were some others that I missed.
