Lens choice for wide open shots
#1 Dave Brunelle
Dave Brunelle
  • 7 posts
Posted 09 March 2009 - 08:54 PM
We're shooting a film in the desert on an arri sr2, We're looking at renting a 16mm and 25mm zeiss prime, we need a lens that will be able to shoot very wide open shots from far away and we're looking for some ideas, would any of those two do the trick?
below is an idea of the distances and frames we'll be shooting
#2 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 09 March 2009 - 08:57 PM
Wide 'Open' refers to the iris setting.. Wide 'Angle' is what you are looking for.
Renting a 9.5, 12, 16 and 25mm should cover your needs.
#3 Dave Brunelle
Dave Brunelle
  • 7 posts
Posted 09 March 2009 - 09:14 PM
true, wide angle of course, i meant open scenery
#4 Chris Keth
Posted 09 March 2009 - 10:38 PM
If you get the suggestions David gave, you would be pretty set. Personally, I would try to add a 6mm to the list. I'm a big fan of that lens' perspective on 16mm, especially outdoors.
#5 Andronico Gonzalez
Andronico Gonzalez
  • 22 posts
  • Mexico
Posted 10 March 2009 - 12:15 AM
I agree with Chris, using the 6.5 gives the most impressive wide angles in 16mm. I prefer to rent all the kit from zeiss, it comes with the 6.5, 9, 12, 16, 25. Just be aware that with the 6.5 everything on frame is going to be on focus, good if that's what you are looking for.
#6 Chris Keth
Posted 12 March 2009 - 11:44 PM
Oh my yes. The hyperfocal distance for that lens is around a meter and a half at a T2.
#7 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 13 March 2009 - 02:38 PM
Personally, I really dislike lenses this wide on 16mm. I don't think that the format has enough resolution to cope.
If you do use one, make sure you shoot at a good deep stop. t5.6 at least.
