Arri ST2 Fresnel & Altman Stage Pin
#1 will griffith
will griffith
Posted 10 March 2009 - 12:55 PM
We have some extra Altman 60A 52-145GM Male connectors.
Will they work with the 2k ST2's smaller cable?
Just wanted to know before handing them to the electrician.
It will be on a 220 circuit.
Will Griffith
#2 JD Hartman
JD Hartman
  • 1763 posts
  • Edison, N.J. U.S.A.
Posted 10 March 2009 - 06:15 PM
I find the information and your question confusing. You're running the 2k(s) off of 220vac? The are lamped with 220v globes? Why do you want to put a 60a bates on the fixture whip? Just because you have them? A 20a bates conector for be sufficient for the amperage draw.
#3 will griffith
will griffith
Posted 10 March 2009 - 06:52 PM
Sorry. :)
Yes.
Yes.
Yes.
Should be fine, but just kind of overkill?
Thanks.
#4 JD Hartman
JD Hartman
  • 1763 posts
Posted 10 March 2009 - 08:16 PM
Should be fine, but why use the more expensive 60a bates, when a 20a bates is about half or less in price? Not familiar with that specific connector (Altman), is is labeled as 220v. This could cause confusion later.
#5 will griffith
will griffith
Posted 12 March 2009 - 08:47 AM
We just wanted to use what we had lying around instead of ordering more.
Thanks for your help.
