Flicker from Kino powered by genny
7 replies to this topic
#1 Jim Hyslop
Jim Hyslop
  • 213 posts
  • 2nd Assistant Camera
  • Toronto, ON, Canada
Posted 12 March 2009 - 08:25 PM
I was 2nd AC on a short film a while back, and we shot a scene on location. One of the lights we used was a KinoFlo. Power was provided by a diesel trailer genny. When I watched the film, I noticed the Kino was flickering. Could that have been caused by the genny not generating exactly 60 Hz, or by the camera being slightly off-sync? Or would you have to see the shot to be able to comment?
Jim
#2 Ryan Thomas
Ryan Thomas
  • 85 posts
  • Grip
  • San Francisco
Posted 12 March 2009 - 10:26 PM
Unless you were shooting some strange shutter, I'm just going to take a stab at it and say that the genny's voltage was a little off. That could be culprit with the flicker. You would just have to adjust the voltage on the genny while you measure it with a voltage meter to make it correct.
Edited by Ryan Thomas, 12 March 2009 - 10:26 PM.
#3 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 13 March 2009 - 09:20 AM
Only the Kino seemed to be flickering? Could be a bad tube. If the generator voltage was low, light from any Tungsten fixtures would have looked a warm on the monitor. Flicker is caused by power frequency not voltage.
#4 Jim Hyslop
Jim Hyslop
  • 213 posts
Posted 14 March 2009 - 01:30 PM
I forgot to mention we were shooting on an Arri SR3, which has a fixed shutter.
Yes, only the Kino was flickering - the tungsten lamps were fine.
A couple of other factoids that may affect things: it was just above freezing, and we ran into problems with the battery later that day. Could the cold or a low battery voltage have affected the camera speed?
Edited by Jim Hyslop, 14 March 2009 - 01:31 PM.
#5 JD Hartman
JD Hartman
  • 1764 posts
Posted 15 March 2009 - 03:27 PM
In general florescent lights don't like the cold. Did it seem like the tubes took a while to reach full brightness. I can't comment on Kino's electronic ballasts, but most floro ballasts will have problems with low temperatures. Reliable operation at low temperature requires a different design.
#6 Adrian Sierkowski
  • 7375 posts
Posted 15 March 2009 - 03:49 PM
Arri SR3 has a variable shutter... If you hold down the "Phase" button on the camera you can be certain of where it was set.
I would say perhaps cold on the floros and/or an older/bad tube.
#7 Jim Hyslop
Jim Hyslop
  • 213 posts
Posted 16 March 2009 - 10:24 PM
Oh. Good thing I was only 2nd AC :-) Thanks for the info. I've downloaded the manual but haven't had a chance to read through it yet.
So, the consensus seems to be either a bad tube or the cold. Is there any kind of test we could have run before shooting?
BTW, the flicker was fairly subtle - most audience members probably wouldn't notice it.
Thanks for all the replies!
#8 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 17 March 2009 - 02:17 AM
SR2 has a fixed shutter. There could be the possibility that the shutter was at a different degree, and it wasn't a safe angle. I know on the sr3 you can shoot 24/25/29.97, and if you were at 29.97, a kino would definitely flicker, as would HMI's.
Too many variables though. Ballast, and the tube seem more reasonable.
