3D puller
10 replies to this topic
#1 Yuka Eto
Yuka Eto
  • 13 posts
  • 2nd Assistant Camera
  • Tokyo, Japan
Posted 16 March 2009 - 11:43 PM
Does anyone know how someone becomes a 3D puller? :huh:
I hear the 3D camera crew is completely different from a "regular" film crew..??
#2 Chris Keth
Posted 16 March 2009 - 11:46 PM
I've never worked on a 3D show but I see no reason why the crew would be completely different.
#3 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 17 March 2009 - 07:16 PM
There was an article about pulling focus and convergence for 3D in the August '08 American Cinematographer, "Journey to the Center of the Earth." Apparently, they had two different pullers, one for focus and one for convergence. As far as learning how to do it, I suspect that it's the same as any other job - once you find out the requirements of the job, you do research to familiarize yourself with the gear and understand how it works. It's the same on your first 35mm job, your first Panavision job, your first anamorphic job, your first IMAX job, etc. Shooting 3D for features is still not that common so I'm sure there are a lot of big time 1st ACs who are in the same position as you. Assistants are smart, you'll figure it out!
The 1st AC on "Journey" was Dennis Rogers, he's based in the SF Bay Area and has done several 3D films, not to mention other huge 2D features. You can find his contact info here: http://reeldirectory...p;categoryid=43. Why don't you call him and ask him about it? (I don't know him personally, but I gripped one day on a commercial that he was 1st'ing and he seemed very nice, he's a surprisingly young guy for the amount of credits he has).
#4 Chris Keth
Posted 17 March 2009 - 07:54 PM
Wow, I can't believe that convergence isn't just mechanically linked to focus!
#5 Yuka Eto
Yuka Eto
  • 13 posts
  • Tokyo, Japan
Posted 17 March 2009 - 09:53 PM
Thank you both for your replies!
Satsuki: I will def contact Paul Marbury, great resume!
#6 Adrian Sierkowski
  • 7375 posts
Posted 17 March 2009 - 10:13 PM
Chris,
I would think that it'd be more interesting to play with convergence separate, might open some things up creatively, ya know?
#7 Chris Keth
Posted 18 March 2009 - 06:08 PM
Chris,
Good point. I hadn't thought about it creatively, only technically where you theoretically want convergence to be at the plane of focus.
#8 Scott Dolan
Scott Dolan
  • 36 posts
Posted 14 April 2009 - 08:31 AM
There's a good article In Feb AC mag which kinda helps describe convergence and interocular distance.
http://www.theasc.co...aline/page2.php
#9 Gunnar Mortensen
Gunnar Mortensen
  • 33 posts
  • Hollywood CA
Posted 15 April 2009 - 01:27 PM
A Focus Pullers job is very similiar in 2D or 3D. Don't get it twisted with the Stereotographer who sets the convergence and 3D effects. The most important task in 3D for a 1st AC is to make sure that the Shutters are inline and you pull focus on both lenses remotely on a Preston or Cmotion.
#10 Larry Nielsen
Larry Nielsen
  • 35 posts
Posted 28 April 2009 - 04:58 PM
I was the 1st AC on "Avatar" in New Zealand, convergence was tied to focus, I had an additional 1st ac who pulled Inter Ocular, at times my I/O puller would override convergence based on the directors wants for a particular shot, and also set the I/O. At points during shooting to control the stereo effect my I/O puller would narrow or lengthen the I/O based on dollie moves, what was in the foreground, and just where I was racking focus to. There is a lot more to running a 3D crew than just pulling focus.
Larry
#11 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 29 April 2009 - 01:59 AM
Larry
Wow, I love this forum! Thanks for the info, Larry. If I can ask, how did you go about prepping for "Avatar"? I imagine you had to do a lot of research and testing to pull off the shots that were asked of your crew. Also, was your I/O puller a specialized "3D guy", or just a regular 1st AC who was trained for the job? Who was calling the shots on the I/O and convergence? You, VFX, DP? Thanks in advance!
