Sound recording to Laptop
#1 Scott Bryant
Scott Bryant
  • 151 posts
  • Nevada
Posted 20 March 2009 - 09:24 PM
I plan on using a Lexicon Lambda Audio interface and garageband or ableton live to record sound. On preliminary tests it seems like the sound levels are pretty low even when I turn up the gain on the audio interface. I'm using an azden sgm-1x microphone (which i know is far from the best), but is this normal in terms of recording for film? Just the fact that it's always a struggle to get the best sound or is this just not a viable way of recording for film?
#2 Phil Rhodes
  • 12161 posts
Posted 21 March 2009 - 12:03 AM
I suspect you will have problems with the amount of noise the laptop itself makes, and also electrical noise caused by its power supply if you run it from the mains - although a competent external USB audio device should be built to avoid that.
Does the mic require phantom power, and if so, can the audio interface supply it, and is that option switched on? Without this I'd expect dead silence, but check. You have, of course, got it connected to a microphone level input rather than a line input - daft but I have to ask.
With any shotgun mic, you should have more than enough control to completely saturate the input if you speak into it at a normal level from a couple of feet away. If that's not the case, something is wrong.
The level to aim for is dependent on a few things. The letter of the rules indicates that you should aim for an average signal level of -20dBFS on a computer, which is, by the standards of things like mp3 files and CD-audio discs, extremely low. This is the level to which broadcast tapes and the like are mastered. However, almost nobody actually works at that level because it makes waveforms tiny on the display and you end up with meters bouncing around at the bottom. It also wastes a lot of bit resolution in the signal chain, especially if you are recording 16bit audio rather than 24. Personally I work at -8 or -12dBFS and reduce levels to normal as a final step, and I have seen production sound people do the same, although of course you take responsibility for avoiding overloading things.
#3 Aman Sahi
Aman Sahi
  • 2 posts
  • Sound Department
Posted 07 April 2009 - 01:20 PM
The audio being low can mean many different things. It can be an equipment issue, your monitoring environment, or it can be an illusion based of perceived loudness. I would have to hear what is going on to advise you better though. If you can post a clip that would help.
