Kodak 7231 BW stock over-exposed
#1 amarogp
amarogp
  • 5 posts
  • paris
Posted 01 April 2009 - 04:53 PM
The DP and myself (1AC) have shot a few tests of 7231 16mm BW kodak film and we did not get what we expected... We shot the test with an aaton LTR, with a 12mm lens. We light the set to a f4 and shot at a correct exposure (f4), then we closed one stop to a f5.6 and finally we closed 2 stops to a f8.
We gave instructions to the lab to push the negative one stop, and definetly the most suitable look is a more grainy and contrasted image in between one and two stops under. At f5.6 (pushed one stop) is clearly over-exposed! That was weird already!
BUT, we also shot 3 shots UNDER-EX to 2 shots OVER-EX to see the latitude results and we were very confused when, at the projecting room, we realized that the image at a normal exposure was one to two shots over-exposed!! It was the same with the previous case as well!And we made sure in class, with 2 lightmeters, 80ASA with HMI's etc etc etc that everything went well. What could be the case? Was it the LAB?
Thanks!
Edited by amarogp, 01 April 2009 - 04:56 PM.
#2 John Sprung
John Sprung
  • 4635 posts
Posted 01 April 2009 - 05:16 PM
They may have given you a "best light" print -- trying to hit the middle of the range you gave them.
#3 Brian Pritchard
Brian Pritchard
  • 330 posts
  • Rushden UK
Posted 02 April 2009 - 02:22 AM
Thanks!
If you expose normally and then push one stop your film will be over-exposed by one stop, one stop under will be normal and 1 stop over will be two stops over.
As John says the result on the screen will depend on how the rush print was graded; best light, graded to grayscale or a standard light. If you wanted to compare the various settings you should really have each scene graded.
Brian
#4 amarogp
amarogp
  • 5 posts
  • paris
Posted 02 April 2009 - 04:26 AM
Brian
Yes but, we gave instructions to the lab to grade to grayscale only in the first shot. Therefore this first shot wich is light correctly at a normal expsure it shoud be fine, not over-exposed right?
Of course if we expose normally and then we push one stop, the result will be OE, but the first shots of the 2 tests we sent (One to be pushed and the other one to be developed normally) are definetely over-exposed... It must have been the lab!!! I have no other explanation to this.... We might have to stick to their development process, so shoot everything 2 stops under, or check again and discover if they misunderstood....
(Teses french labs..... :)
Thank you all!
#5 Simon Wyss
Simon Wyss
  • 1492 posts
  • Basel, Switzerland
Posted 02 April 2009 - 04:48 AM
Brian
I beg your pardon, but if one pushes the film will be overdeveloped, not overexposed. What a confusion here !
#6 Brian Pritchard
Brian Pritchard
  • 330 posts
  • Rushden UK
Posted 02 April 2009 - 01:29 PM
There is no confusion. The purpose of push processing is to effectively increase the exposure index. If you expose normally and push process you will get a heavier and higher contrast image. If this was printed at the same light as a normally exposed negative the pushed image would appear over exposed, that is thin.
Brian
#7 amarogp
amarogp
  • 5 posts
  • paris
Posted 03 April 2009 - 12:41 PM
Going back to the over-exposure issue, I have talked to the lab and they told me that "they gave the wrong values to the telecine and thats why it looks over-exposed". I am going to the LAB on monday to try and process the telecine properly. I will also bring a few meters of unexposed stock to verify the gamma curve and therefore double-check the dynamic range of the film.
Thank you all
Amaro
