In camera ramp with a telecine ramp?
#1 grant mcphee
grant mcphee
  • 93 posts
  • 2nd Assistant Camera
  • UK, Scotland
Posted 10 April 2009 - 12:44 PM
I'm looking to film a fairground ride. I want a shot to start with 'speed trails' as it spins around and then move into 'normal' motion within the same shot, without changing the appearance of speed.
I thought I would ramp from something like 6fps to 25 and ask the lab to do a telecine ramp to match it, in effect a telecine step print but with a ramp.
How achievable is this?
thanks
#2 Kent Kumpula
Kent Kumpula
  • 91 posts
  • Digital Image Technician
  • Sweden
Posted 10 April 2009 - 01:31 PM
Just have it transferred frame-accurate at 25fps (for PAL), then you can fiddle with the speedramp while editing to get it just the way you want.
#3 timHealy
timHealy
  • 1262 posts
Posted 10 April 2009 - 03:40 PM
thanks
That sounds really tricky. You would need some way of marking the frame you start your ramp and the frame you finish your ramp and everything in between to be able to match that in post to the transfer machine. You would have to do camera and post research to see if is technically possible, but I have a feeling the answer is no. But try and make calls, you may be surprised at what you find out.
So maybe Kent's method could be easiest. You would get the motion blur in the slower frames from your exposed negative, but you may have to play and wing it in your post method.
Best
Tim
Edited by timHealy, 10 April 2009 - 03:40 PM.
#4 Robert Houllahan
Robert Houllahan
  • 1626 posts
  • Providence R.I.
Posted 10 April 2009 - 04:22 PM
In my experience with all sort of telecine I don't think you would be able to have the machine do a ramp maybe a speed change from one to the other on the fly but usually you have to stop the machine and setup for a different speed. Getting frames and doing a speed change in after effects would be better.
-Rob-
