Any AC's out there modified a Red LCD yet?
7 replies to this topic
#1 Scott Dolan
Scott Dolan
  • 36 posts
Posted 16 April 2009 - 06:05 AM
Hi all,
Just curious if anyone has had a go at, or knows anyone who has modified a Red Pro LCD 7" or 5.6" to take a HD-SDI signal from a non-Red camera? Surely someone has rewired one by now to take a BNC and 12V power input?
If anyone knows of a wiring diagram out there it would be much appreciated.
Cheers
#2 Chris Keth
Posted 16 April 2009 - 06:04 PM
Hi all,
Cheers
Would make a pretty nice little monitor. I wish RED would make their stuff a little more standardized rather than going off just to be different. I'm certainly not going to drop the cash on one to, possibly, destroy it.
#3 Kar Wai Ng
Kar Wai Ng
  • 127 posts
  • Toronto, Canada
Posted 16 April 2009 - 11:31 PM
It is my understanding that the majority of the electronics and circuitry required to drive the RED LCD's actually reside in the camera body itself, which is why it has to connect via a lemo connector with many pins. It's also why the LCD itself is so thin. I don't think it's possible to rewire it to accept an HD-SDI signal because all the signal processing is done by the camera, not to mention that the panel also has a non-standard resolution.
#4 Scott Dolan
Scott Dolan
  • 36 posts
Posted 22 April 2009 - 05:19 AM
Ofcourse :D
That explains everything.
Thanks mate
#5 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 16 May 2009 - 01:18 AM
Would this work? Third item from bottom: http://www.ortec-onl...es/adapters.htm
#6 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 17 May 2009 - 08:27 AM
That monitor isn't very good though.... Sure, when you're right in front of it at the exact perfect angle it looks good, but if you're off axis by a degree or two it's un-viewable. I think there are quite a few much better monitors out there that don't need modifying. Is it how cheap it is that makes it attractive?
#7 Chris Keth
Posted 17 May 2009 - 03:49 PM
I like how light and thin it is.
#8 Brad Grimmett
Brad Grimmett
  • 2660 posts
Posted 17 May 2009 - 07:39 PM
Yeah, it does have that going for it.
