Light quality of older ARRI Fresnels (pre-1950)
#1 Marc Roessler
Marc Roessler
  • 264 posts
Posted 19 April 2009 - 03:00 PM
What are your experiences with the older-style ARRI fresnels?
(similar to this one http://eventtechnike...eum/ARRIalt.jpg )
The one I tried (1 kW) had a noticeably worse light qualitiy than the modern fresnels:
- uneven field of light with some very light circles visible in the projected light (looked as if it projected the fresnel lens pattern, esp. towards the edges
- a slighly darker patch growing in the center when flooding the thing
- quite some diffuse light spill from the front lens (probably because it is slightly roughened up at its lamp-facing side)
- spill, spill, spill from the top&bottom ventilation cuts... this seems to be due to the design: there is some metal to shield most of the light, but no real light trap as in newer fresnels
Also I feel that the beam is not as defined as with newer fixtures.
Is this puppy just misaligned or were the lights in general not that good back then?
Greetings,
Marc
Edited by Marc Roessler, 19 April 2009 - 03:01 PM.
#2 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 19 April 2009 - 03:19 PM
Think it's just like that: They weren't so good. You should see the bulb of these - no questions asked!
#3 Marc Roessler
Marc Roessler
  • 264 posts
Posted 19 April 2009 - 05:05 PM
yes the bulbs are enormous... but I don't see why this by itself should be the cause for bad light..? the mirror needs to be placed further away (and has to have a larger radius of curvature), but other than that...? Besides, those were also available later with G22 halogen lamps... don't know whether this was standard from ARRI or retrofitted later, though...
