Light for Chimera
16 replies to this topic
#1 Tom Savige
Tom Savige
  • 21 posts
  • Melbourne, Australia
Posted 12 May 2009 - 08:13 PM
Hello,
I am buying a Chimera soon and I'm just wondering what kind of light is best for it. Some people say that you should use a fresnel in them but I dont see the what the problem is with using an open faced light in one.
Thanks, Tom
Posted 12 May 2009 - 08:49 PM
Hello,
Thanks, Tom
Either works as long as it has a nice even flood position. The only problem I've had with some brands of lightweight open-faces is that the yokes are too flimsy to handle the weight of the Chimera. Also, some of them are not easy to drop scrims into. I'm thinking of Ianero Blondes and Redheads really.
#3 Tom Savige
Tom Savige
  • 21 posts
Posted 12 May 2009 - 09:34 PM
Thanks David, I was actually going to get the Ianero ones, so thanks for warning me. Nothing worse than finding out they have flimsy yokes on set. I'll make sure to buy Arri :D
#4 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 12 May 2009 - 10:58 PM
I've had problems with big chimera's on arri 2k's; with the chimera being too heavy for the yolk. I'm sure it's the same for most lights.
#5 A. Whitehouse
A. Whitehouse
  • 267 posts
  • Melbourne
Posted 13 May 2009 - 12:55 AM
As have I. Moving up to a 2.5k HMI and its handled the weight but nothing less than that has. I burnt a hole in one once when a blondie drooped into it. Quite a pity. Very good tool though the chimera, I like them a lot.
#6 Bob Hayes
Bob Hayes
  • 1087 posts
  • Culver City, California
Posted 13 May 2009 - 01:02 AM
I usually rig some sort of a support to keep the Chimeras from drooping. I’m glad you mentioned it because I have been thinking of manufacturing a bracket.
I often just clip diffusion inside the Chimera to knock the light level down. I clip it to the frame of the soft light half way between the light and the front of the box.
#7 David Auner aac
David Auner aac
  • 1117 posts
Posted 13 May 2009 - 01:43 AM
Hi Tom,
I use an Arrilite 800 in my VideoPro S. I'm really happy with it. I figured it gives you more light per watt than a fresnel does and it stays with the Chimera all the time too. So I thought to use a fresnel was kinda wasting money as you couldn't really use it's advantages as it's in there. If you rarely use the Chimera though, maybe a fresnel would be a a smarter choice after all (if you like fresnels to begin with)...
Cheers, Dave
#8 Tom Savige
Tom Savige
  • 21 posts
Posted 14 May 2009 - 06:12 PM
Thanks for your help guys, I am thinking of buying a big chimera so whats the cheapest light that has a strong yolk? I was also wondering how much light the diffusion pannel on the front of it loose. would I just be better off buying a Kino Flo?
Thanks, Tom
#9 Bruce Taylor
Bruce Taylor
  • 482 posts
Posted 14 May 2009 - 08:02 PM
The 2k open face Mighty Mole is reasonably heavy duty and puts out a lot of light. I have picked several used ones from ebay for ~$200.
Bruce Taylor
www.indi35.com
#10 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 15 May 2009 - 11:42 AM
Thanks, Tom
How big is big? I have a 4'x3' Chimera which just about works ok with Arri 650w fresnels or 800w open face. It tends to fall a little, so I occasionally use a stand to give it some support. It would also work well with a 1k or 2k fresnel. You will lose some intensity due to the diff on the front, probably somewhere around 1 - 1.5 stops, nothing too major. It really depends on what material has been used, and this varies from make to make.
If you buy a kinoflo then you only have a soft light. A fresnel (or open face) lamp with a chimera is a much more flexible tool.
#11 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 15 May 2009 - 01:30 PM
On most fixtures, open face, fresnel, etc., the yoke only lock on one side. The other side has a pivot bolt it set to provide some friction or tension so that the head doesn't immediately fall forward when the lock is loosened. You could replace the bolt with a matching locking handle and tighten it down when using a Chimera.
#12 A. Whitehouse
A. Whitehouse
  • 267 posts
  • Melbourne
Posted 15 May 2009 - 08:39 PM
Very good tip, thanks JD.
#13 Brian Drysdale
  • 5197 posts
Posted 16 May 2009 - 02:44 PM
Because of position of the yoke, the Redheads can tend to droop under their own barndoor's wieght, never mind having a Chimera in front.
#14 John-Erling Holmenes Fredriksen
  • 83 posts
  • Oslo, Norway
Posted 16 May 2009 - 02:59 PM
Another advantage tungsten units have over KinoFlo's that should be mentioned is color. Personally I much prefer the color you can get from from a tungsten unit over the color a tungsten KinoFlo-bulb produces. KinoFlo have lots of other advantages though. And you get a lot of light per watt.
#15 Marc Galerne
Marc Galerne
  • 25 posts
  • FRANCE
Posted 18 May 2009 - 03:30 AM
Ideal light for Chimera or any light bank in general is a bare bulb type fixture. The reason is Chimera started in the photo business and therefore created lightbanks to accomodate strobes. To better cover the front diffusion, they designed their banks to reflect light from the internal side in a paralel way. So whatever the size of the light bank, the 360° unit you will use (whatever it's wattage) will evenly cover your front diffusion resulting in a softer result and better light quality. This also avoid to use an internal baffle to spread the beam even more when using regular lights (open face, fresnel, par...). You end up having more output and softer effect.
A Bug 800 W is giving more output (and a softer light) in a Chimera than a 1200W Par (with internal baffle). You can put a Large and still cover the all surface. Try this with a regular light (with reflector), you'll end up with a spot in the center of the light bank.
There are lots of bare bulb fixtures both in tungsten and HMI available.
Hope this helps.
#16 Jean Allard
Jean Allard
  • 2 posts
Posted 18 May 2009 - 05:17 PM
I'dd take a look at the triolet line of barebulbs fixture
by chimera themselves, they come with speedring for
around 250$ and can go to up to 1k.
#17 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 27 May 2009 - 04:40 PM
Rifalites are quite nice as well. Never had a good experience with redheads and chimeras.
Yokes definitely too weak.
