Best place to sit when watching 3D?
24 replies to this topic
#1 Karel Bata
Karel Bata
  • 487 posts
  • London - a rather posh bit
Posted 16 May 2009 - 08:56 AM
I 've just read a fascinating American Cinematographer article on Coraline and am looking forward to soaking it all in.
My problem is that I usually sit in the front row (ever since i was a kid) but that's not the best place for 3D. Is there a simple formula for working out where you should be to optimise the effect without getting a headache?
Cheers! :D
#2 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 16 May 2009 - 10:14 AM
Cheers! :D
I think most projection is set about 2/3 the way back in the center.
#3 Brian Drysdale
  • 5193 posts
Posted 16 May 2009 - 10:23 AM
I usually sit in the centre lined up with the surround speakers on either side. that seems to be roughly 1.5 to 2 screen widths back, although that can vary a bit depending on the layout of the theatre.
#4 Phil Rhodes
  • 12161 posts
Posted 16 May 2009 - 10:37 AM
For 3D showings? Well, about 80" to the left of the screen centreline at my local cinema, which will put you in the 2D screen next door.
By this technique, it's possible to avoid leaving with a splitting headache.
#5 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 16 May 2009 - 04:49 PM
priceless.
#6 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 18 May 2009 - 06:43 PM
How did I pick this as a Phil Rhodes comment before I even looked at the sidebar ;)
Seriously Phil, if you get a headache from good, modern 3D screenings, then it's the content rather than the technology. (And that is perfectly believable, I'm still waiting to see a film that is worth the effort, in 3D).
In any case, 3D is a sham. If it was really 3D, then it would matter where you sat, as every seat would give you a different view of the scene.
#7 Chris Keth
Posted 18 May 2009 - 07:34 PM
I try to get seats in the center of the theater about a third or halfway back, whether the movie is 3D or not. I saw Coraline recently in 3D and it looks very, very nice shown like that.
#8 Phil Rhodes
  • 12161 posts
Posted 18 May 2009 - 08:13 PM
Last things first:
Yes. This is 2.5D at best.
Uhoh - you've been subsumed by the 3D mafia!
I think part of the problem comes from the convergence/focus disparity- they can persuade you that the object is 200 feet away with fake stereoscopy, but you still need to focus on the image 40 feet away.
Then there's cuts. Your eyes aren't usually asked to reconverge in 1/48 of a second, since you aren't capable of changing position fast enough. There seems to be little or no attention paid to keeping the changes in convergence minimised between takes, since this makes it less punch-in-the-face spectacular.
Then there is the issue that stereoscopic vision doesn't really operate beyond thirty or forty feet in any case, so there's a tendency to force the issue by scaling the virtual space. This is a technique whereby something that would be happening between a hundred and a thousand feet is represented as happening between five and ten, in terms of stereoscopy. This avoids the sad fact that in the most spectacular landscape shots, the 3D effect should by rights be almost invisible - but of course this is not what Mr. Producer is paying for, so...
All of these things create a fairly serious disagreement in your visual cortex. They aren't easy to solve and no current technique even tries; you get very dirty looks if you mention them to 3D people because they know it's a huge problem and they haven't got the foggiest idea how to solve them, or feel that they must do them in order to justify their existence ("Wow, lookee that, Mr. Producer! We're great! Hire us!"), or possibly actually don't seem to know that they're doing it, as frequently happens with the compressed-space issue. One major 3D release (which made me very nearly hurl) does that all the time, and the guys who did it, when interviewed, don't seem to have any idea that they did. One is left with the alarming feeling that they just wound the convergence controls around until the producers started to applaud.
That would be bad enough, but we have a 3D establishment at the moment who likes to promote the idea that they've solved all the problems with whizzy new technology. In fact, the technology being used now differs only in the detail from the very earliest days of anaglyph, and has exactly the same problems. They're perfect messiahs who have brough salvation to the film industry.
Well, bollocks, it still makes me feel sick and that's not my fault. I can only hope that the major 3D systems start offering people the option of glasses with two identical lenses so that we don't have to suffer this literally mindbending mess if we don't want to.
#9 Russell Scott
Russell Scott
  • 42 posts
Posted 19 May 2009 - 03:10 AM
The best place to sit is generally close to the back - this will put you in the original position for the stereo images. In other words you are trying to put yourself the closest you can to the 'camera view', it will also minimise any gain created by the silver screen (if it has one). having said that it is possible to change the 'sweet spot' of a cinema to any point at all, not that cinemas will do that - just that you can.
Phil is correct that there could still be problems, but is very wrong in his description of them!
The separation/convergence of the cameras has nothing to do with the problems viewing stereo images causes. Yes you can exaggerate stereo but the eyes are easily capable of dealing with that (your eye can converge to your nose through to directly parallel, so no amount of extra convergence will tax them. The problem is the focusing mechanism of the eyes. The eye must gather their 'stereo' information from the screen, if they then must converge something with too great stereo, they cannot maintain their focus on the screen (but will try to) and thus the eyes are strained.
Its actually very easy to control - there is a zone in which the eyes do not strain in their focus, but like cinematography there are people who are good at it and there are people who are bad at it.
for stereo, it does matter where you sit (but obviously not in the way you are meaning), since every seat will give you a different stereo parallax. The disparity of the stereo parallax vs the actual image parallax is why the side seating is less than ideal.
why not just go to 2d screenings of the same movies, then you won't even need the glasses?
:lol:
#10 Karel Bata
Karel Bata
  • 487 posts
Posted 19 May 2009 - 04:58 AM
Phil, a lot of your criticism seems based on the argument that 3D is getting your eyes/brain to do something unnatural. But since when is watching a film like watching the real thing anyway? Does it also give you a headache to focus on a close up that is forty feet away? Cutting from that to a wide shot should (in theory) make you feel sick too. Hell, a track/zoom should send people out of the theatres in droves. But it doesn't.
Film is an evolving language and 3D is particularly difficult to get 'right', if there is such a thing. Doesn't mean it's not worth trying. I think it's a lot of fun, and I envy those working at the cutting edge of something so challenging.
#11 Phil Rhodes
  • 12161 posts
Posted 19 May 2009 - 06:28 AM
Yes, yes, I know, everything's perfect and you've solved all the problems and I'm just wrong. But:
You keep saying that. I'll keep throwing up. Deal?
#12 Karel Bata
Karel Bata
  • 487 posts
Posted 19 May 2009 - 06:46 AM
So petulant...
:D
#13 Russell Scott
Russell Scott
  • 42 posts
Posted 19 May 2009 - 07:01 AM
Actually I've clearly stated there are problems. What you're describing as the problem is in fact *not* the problem. There is so much misinformation about stereo - I'm trying to help address that problem, I've posted in a number of these threads.
Exaggerating the stereographic effect on, for example, a landscape, will not produce strain, unless that exaggeration is done incorrectly.
As I hinted, I don't really get your position. If a car company produces a blue version of a car you prefer in white, surely the option you take is just to buy the white one? Why complain about them giving you options?
#14 Karel Bata
Karel Bata
  • 487 posts
Posted 19 May 2009 - 07:18 AM
There is another problem though, isn't there? If optimal seating is in the middle and at least half way back, doesn't that mean that over half the audience are losing out?
And forgive my ignorance, but is the 'screen size':'depth of cinema' ratio always the same? I thought there was some variance, which in turn would affect the best seating position in a 3D screening..? I had originally expected someone to say something like "sit 3x the width of the screen away."
Edited by Karel Bata, 19 May 2009 - 07:19 AM.
#15 Russell Scott
Russell Scott
  • 42 posts
Posted 19 May 2009 - 07:37 AM
thats yes and yes! in relation to the last question, generally you find that up the back(ish) gives the best result not just for the width/depth ratio but also because you are higher up and hence the image perspective and the stereo that your brain generates are closer. The problem is that many theatres aren't designed for stereo, they are simply converted to stereo projection. this lack of standardisation - coupled with the fact that many don't even realise that screen size makes a difference - makes it hard to give a direct answer of where exactly to sit.
#16 Karel Bata
Karel Bata
  • 487 posts
Posted 19 May 2009 - 07:49 AM
So basically towards the back of a really good modern cinema or of an IMAX.
Cheers! :D
p.s. Anyone remember John Walter's 'smell-o-vision'? I've still got the scratch card! B)
#17 Phil Rhodes
  • 12161 posts
Posted 19 May 2009 - 08:40 AM
Because there's a bunch of stereophiles wandering around telling me I'm some sort of idiot for having the temerity, the unmitigated intestinal temerity, to be made to feel ill by their work.
I'm observing a real 3D scene involving a computer keyboard and a monitor right now, and it isn't making me feel unwell. Observing scenes with 3D information reconstructed from stereography does make me feel unwell, particularly and identifiably when the aforementioned problems are present, and this means one of two things:
- I have found a way of making myself feel unwell by the power of thought alone, and I am craftily using this ability to spite you,
or
- There is something wrong with your techniques.
-P
#18 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 19 May 2009 - 09:12 AM
By design the "sweet spot" in theaters with stadium style seating is the row of seats level with the center of the screen. In the AMC mulitplex where I see most of my first run movies that row is at a crossover aisle. Which conveniently also means no-ones sitting immediately in front of you. While I can't be certain, it makes sense that aisle is also the best for 3D since you're centered on the screen, therefore at the camera POV.
#19 Karel Bata
Karel Bata
  • 487 posts
Posted 19 May 2009 - 01:10 PM
Oh why don't they bring back the old cinemas where you could sit at the front of the circle.. :(
#20 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 19 May 2009 - 10:29 PM
Well No, Phil, I've been to look at a variety of 3D presentations and made up my mind. And I didn't get headaches.
We perceive depth with the help of a dozen or more cues - parallax, focus, convergence, relative size, haze/desaturation of distant objects, and so on. The job of any 3D system, as with any 2D system, is to fool us with as many of those cues as possible, while also producing images that don't have their own artefacts - such as ghosting, etc. And if we can watch the images with a little constraint on our comfort as possible that helps too.
The latest round of 3D addresses (OK, not perfectly) many more of these issues than previously. Circular polarisers allow you to tilt your head without getting ghosting. The sudden jumps in distance/convergence that you speak of can be addressed by rapid predictive convergence pulls just before the cut. And so on.
OK, 3D isn't perfect. Neither is 2D. Neither is stereo sound, or 5.1 sound, or 22.2 sound or any other means of reproduction.
My point is that comments on 3D or any other system should be based on current experience interpreted by theoretical considerations, not on theoretical arguments based on old or even anecdotal experience.
