Konvas spring motor
#1 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 16 May 2009 - 10:58 AM
Has anyone here ever had and used a Konvas spring motor for a 1M, or even seen one? How long will they run on one wind-up?
#2 John Sprung
John Sprung
  • 4635 posts
Posted 16 May 2009 - 02:17 PM
You'd probably have to make one. Something similar to an Eyemo or Edison cylinder phonograph spring should do it. Start with a piece of 4" schedule 80 black pipe an inch long, weld a plate on one side, and fill it with 1" blue tempered clock spring, maybe 60 - 80 ft, IIRC. Gotta learn how to draw the temper on the ends and make the attachments. Load it on a lathe, big springs like that pack a whole lot of energy in the unwound position, let alone when you crank them up. Then all you need are gears and a governor.
#3 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
Posted 16 May 2009 - 03:20 PM
Okay, John. Nothing to it. I've got a few minutes to spare today. I'll knock one out.
#4 John Sprung
John Sprung
  • 4635 posts
Posted 16 May 2009 - 08:38 PM
Great -- maybe design it as a multi-purpose spring motor that you could interface to the Konvas or to any of the Arri model II series.... Hmmm -- what else might you want to drive with it?
#5 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 16 May 2009 - 08:47 PM
Hi John,
Sometimes I can't help myself. I'm always seeing the funny side of things.
Scroll down
Spring
Has
Sprung !!!!
Sorry John, I owe you an Irish beer. You could always call me Hickory Dickery O'Dockery..........
#6 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 16 May 2009 - 11:07 PM
I have one thanks to a member of this board to whom I will be eternally grateful, though I've never used it and I'm not sure if my camera, a KSR-1, was designed to work with it but regardless, I'll have a modification done to MAKE it work at some point if I have to. It is in MINT condition, VERY cool and rare as hen's teeth.
