Adapter to use Arri PL lenses on Std mount camera
#1 Peter Werner
Peter Werner
  • 2 posts
Posted 18 May 2009 - 02:41 PM
I am looking for a way to use PL lenses on a Panasonic G1 mft (Micro Four Third) still camera. The G1 can use Std mount, Nikon, M42 and other lenses with adapters that are readily available on ebay for around $150, but I have not seen any PL to mft (or PL to Std) adapters.
Peter
See for instance Available mft adapters
Edited by Peter Werner, 18 May 2009 - 02:45 PM.
#2 Hunter Hampton
Hunter Hampton
  • 170 posts
Posted 18 May 2009 - 08:51 PM
You mean like this?
This is my DIY version using 2 adapters to get PL lenses on my camera, but there is a fellow over at "Hot Rod Cameras" making a native PL adapter for the m4/3 mount.
Edited by hunter richards, 18 May 2009 - 08:52 PM.
#3 Alejandro Renteria
Alejandro Renteria
  • 1 posts
Posted 19 May 2009 - 12:31 AM
I will really appreciate if you will share your knowledge in how to.
I'm trying to mount PL lens in the Nikon d90
You mean like this?
#4 Peter Werner
Peter Werner
  • 2 posts
Posted 19 May 2009 - 01:18 AM
You mean like this?
Exactly
Could you please explain in more detail what adapters you are using. Did you make the PL adapter yourself? Converting PL to what mount?
#5 Hunter Hampton
Hunter Hampton
  • 170 posts
Posted 19 May 2009 - 12:13 PM
Alejandro-
It wont be easy to put a PL mount on a nikon camera, because of the FFD difference in Nikon and PL mount, you would most likely need to literally bore out a hole in your nikon camera. The m4/3 FFD is so short that its easy to add a PL mount onto it.
Peter-
I used a custom machined PL to leica M adapter - and then a leica M to m4/3. I then used epoxy to bond the two permanently. I didnt know at the time that Hot Rod Cameras was working on one or else I would have bought theirs. The m4/3 mount is very very weak, so what they did was build a whole PL mount support that attaches under the camera so you can put heavy lenses on without stressing the m4/3 mount. With the one I made, you have to support the lens at all times with your spare hand (even with with smaller lenses).
