Avid Media Composer and Cineform's NeoScene
#1 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 21 May 2009 - 07:20 PM
I'm looking at buying Cineform's NeoScene to use to reverse telecine (pullup) Canon HV20/30 footage shot in the camera's 24p mode. I want to convert from the 24p encoded in the camera's 60i data stream and then save it as true 24p .AVI files. Next I want to import it into my Media Composer as a true 24p project. Anyone doing this successfully? I've read that NeoScene is bulletproof at recognizing the 24p/60i HDV cadence and as a result its reverse telecine works correctly.
#2 Peter Moretti
Peter Moretti
  • 306 posts
  • Sherman Oaks, CA
Posted 22 May 2009 - 03:38 AM
I do this fairly regularly, but I don't use NeoScene. I use TMPGEnc Xpress 4.0. It's an excellent program for transcoding, changing frame rates, removing a pulldown, capturing from DVD's and more. Probably the best $100 I've spent on editing.
But it's main advantage over Cineform is that it will transcode HV-20 footage into a Quciktime file of any DNxHD format. This file can then be fast imported into Avid.
You do need a program to capture the original HV-20 footage with. I use Sony Vegas b/c I have it on my computer. But there are many free capture programs out there.
So the steps are: capture w/ another NLE or capture program, use TMPGEnc Xpress 4.0 to transcode the HDV file into a 23.976 DNxHD .mov file, fast import file into Media Composer.
#3 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 23 May 2009 - 10:47 PM
Thank you Peter, I'm looking into it.
