Bolex EL battery RECELL
14 replies to this topic
#1 ericyeong
ericyeong
  • 24 posts
Posted 26 May 2009 - 10:25 AM
Hi, anyone out there could explain my problem?? I've re-celled my 12V on board Bolex EL battery with the higher ampere 2500mAh(original was 800mAh)... I'm pretty sure the wire connection is right and nothing is loose. When I plugged it to my camera, the fuse blew.. checked my battery with voltage tester, it shown 12V... Anyone can tell me what's wrong with it?? :( Would it be the higher amp power? (which I don't think so..)... your help would be appreciated...
Regards,
Eric
#2 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 01 June 2009 - 10:58 AM
Check if it was the right fuse. I can look it up which one if you need to know.
#3 Erkan Umut
Erkan Umut
  • 215 posts
  • Istanbul
Posted 07 June 2009 - 11:55 AM
Regards,
Eric
The voltage is important. Amperes show the battery capacity. There could be another problem. If everything would be ok, any fuse could be handle it. Ask to Bolex Switzerland for the fuse spec. Try it with another battery. Maybe a shortcircuit?
#4 ericyeong
ericyeong
  • 24 posts
Posted 07 June 2009 - 08:18 PM
Hi Erkan, I've just received another EL battery that I bought from Ebay, charged and plugged in my camera.. it works. I'm just confused...
#5 John Sprung
John Sprung
  • 4635 posts
Posted 08 June 2009 - 02:48 AM
Those numbers sound like the old ones were nickel cadmium, and the new ones are nickel metal hydride AA cells. The new ones could be a little higher voltage than the originals. Fully charge both batteries, and compare the voltages.
#6 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 10 June 2009 - 07:47 PM
I have recelled the EL battery packs myself with new NiMH cells.
I just not wanted to go with the older NiCad cells just to use the original Bolex charger so i got it all new.
Voltage is still 1,2 Volts each and shouldn't be a problem with the fuse or electric / electronics.
#7 flavio filho
flavio filho
  • 247 posts
Posted 03 May 2011 - 02:10 PM
Hi Oliver.
How did you operate to re-cell your EL battery?
I'm about to receive My Bolex El and I know it will come with the battery dead.
Any little helps.
Edited by flavio filho, 03 May 2011 - 02:11 PM.
#8 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 05 May 2011 - 07:09 PM
Easy. Get a WKV40 DIN 4-pin plug (female for the battery - male for the charger). If you want to recell the original compartment you need 10 batteries with soldering taps each. If you go this route you also need a new NiMH charger wired to charge the new packs.
I'd rather use a new compartment because this one is easier to build, more versatile and uses standard rechargeable batteries. And a standard charger. Read the BOLEX EL MANUAL on page 20 (its 21 in the PDF). The fourth socket diagram shows the correct wiring.
#9 Tom Bert
Tom Bert
Posted 30 January 2013 - 11:26 AM
Hi Oliver, hi Flavio, and everybody else,
i'm in need of some help about EL battery.
My spare batteries have been stolen at the airport, and my other "on board" original battery is just dead.
So i have to re-cell the dead battery + buy 2 spare ones.
A few questions:
- has your re-celled NiMH battery worked fine with your Bolex camera ? I'm asking this because the tech from Bolex suggested me to keep NiCd batteries not to risk to create problems to the camera. But seems you had a positive experience switching to NiMH?
- do you know any facilites that take care of re-celling and assembling batteries ? I'm not very good in this kind of "do-it-yourself" assembly and would be more reassured if some pro could help me out on this.
Thanks for your time gentlemen :)
#10 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 30 January 2013 - 04:05 PM
Tom, where are you located?
Jean-Louis
#11 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 31 January 2013 - 10:27 AM
Volts don't blow fuses, amps do. So it must be an under-rated fuse or a short circuit.
#12 Tom Bert
Tom Bert
Posted 31 January 2013 - 01:39 PM
Hi Jean-Louis,
I'm based in Lisbon, Portugal.
#13 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 31 January 2013 - 06:35 PM
I do this kind of work but I am in Montreal, Canada so that may be a little far for you.
I can recommend http://www.microdeltabalears.com/ in Palma de Mallorca. They should be able to help you.
Any 12V DC battery pack will work. The higher the capacity, the more autonomy you will have.
Cheers,
Jean-Louis
#14 Tom Bert
Tom Bert
Posted 31 January 2013 - 07:44 PM
Hi Jean-Louis
thank you very much for the info.
In the meantime is there a way a contact you privately to know how much would that cost to do it in montreal ?
thanks again
tom
#15 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 31 January 2013 - 08:53 PM
Sure. My email: bolextech@gmail.com
